Brake lamp warning light
Old Nov 8, 2012 | 10:59 AM
professorman's Avatar
Default Brake lamp warning light
I have a 94 Accord LX 5Spd. My brake lamp warning light came on about a week ago. This is the one that tells you when a bulb is blown. I have checked all my bulbs and they all work properly. The dual filament brake lights works. Park light=single filament, brake lift =bright filament and the high mount brake light works.
I have checked everything, both bulbs work. There are no coronations on the sockets. Does anyone else have any ideas of what to check next?
Old Nov 8, 2012 | 03:03 PM
yungmulacrx's Avatar
Default Re: Brake lamp warning light
Make sure your brake fluid level is good.. I had a bad brake light that would flicker on and off but worked everytime i tried checking them so i swapped a new bulb in and never seen the light come on again.. Hopefully this helps..
Old Nov 9, 2012 | 02:50 PM
Ha, Sounds possible to have a flickering bulb. I will try swapping the bulbs out and see.
Old Oct 24, 2013 | 09:34 AM
I have had this problem for 1 year now, with all my bulbs working. Is there any advanced methods to check why the indicator light is on to say that my bulb is blown?
Old Oct 24, 2013 | 11:23 PM
holmesnmanny's Avatar
The system checks to see if the same amount of watts is coming from either side so if you use different bulbs it could have this problem. Some bulbs will fit but have different watt ratings. Also the sensor that checks this could be bad too.
Old Oct 26, 2013 | 03:47 PM
Any idea where the sensor is located?
Old Oct 27, 2013 | 06:28 AM
Lost Again's Avatar
Left rear tail light.
barfo
Feb 8, 2015 04:12 PM
SCinCA
Oct 6, 2014 06:35 PM
Mishako129
Jun 4, 2013 10:50 AM
regular_guy_49
Dec 15, 2011 07:39 PM
stranskydesign
Honda CR-V & Element
Aug 3, 2010 05:55 AM
