2004 honda civic OVERHEAT
Old Nov 8, 2012 | 07:32 AM
Louiethegreat's Avatar
Icon6 2004 honda civic OVERHEAT
My civic starts to spit the water out of the reservoir tank when I drive fast n I always have to b checking the water so it wont over heat n e one know y its doing this thanks!!
Old Nov 8, 2012 | 07:47 AM
Rtype16's Avatar
Default Re: 2004 honda civic OVERHEAT
You may have a blown head gasket. Do a leak down on the engine to see what is going on. Also Honda around your year had a defective block recall. You may want to look into that as well.
Old Nov 8, 2012 | 11:31 AM
If it was the headgasket wont there b water in the oil wat would b wrong with the block
Old Nov 10, 2012 | 02:24 AM
josephcmiller2's Avatar
There is more than one way to blow a head gasket. One way is water leaking into oil. The other is water leaking into cylinders. You seem to have water leaking into cylinders. This also means when you drive fast the cylinders push air back into the coolant system and push the water out of the reservoir.
Old Nov 13, 2012 | 08:39 AM
Is there a way to check if water is in the cylinder and how can I fix it
raider1qaz
14
Feb 9, 2013 09:12 PM
hmtcrxsir
11
Jul 23, 2007 07:17 PM
ronqqq
Dec 6, 2006 11:26 PM
PatrickGSR94
Jan 13, 2005 12:21 AM
