Bisimoto F22 H beam rod and 9.1:1 piston combo..thoughts? pros/cons?
Old Nov 8, 2012 | 07:19 AM
bigbpatel's Avatar
Default Bisimoto F22 H beam rod and 9.1:1 piston combo..thoughts? pros/cons?
Anybody have an thoughts on what forged pistons and rods to get for a F22b1 (sohc vtec)
i was thinkin about gettin bisimoto's deal for 759 shipped
"F22A/F22B H beam rod and 9.1:1 piston combo! Set of 4 replacement H beam steel LONG rods for the F22A, and F22B, coupled with 86mm custom Bisimoto spec forged pistons at 9.1:1 compression ratio. Excellent for 300-800whp."
I want about 350 whp, 400ish max.
not turboing for a month or two after the rebuild is complete, but thinkin about a slightly larger turbo, not huge, dont know which one but dont want a small one for sure.
thanks in advance!
Old Nov 8, 2012 | 09:14 AM
Julio@Bisimoto's Avatar
Icon3 Re: Bisimoto F22 H beam rod and 9.1:1 piston combo..thoughts? pros/cons?
From what I read about your power goals, it is going to require aftermarket rods and forged pistons to be reliable.
Bisimoto custom forged pistons are manufacturer by Arias Pistons here in Southern California and are machined from the highest quality billet aluminum to insure integrity in a very lightweight design. Bisimoto steel H-beam rods have also been proven to handle 800whp with a proper tune and feature ARP bolts to handle high rpm use.
This will give you piece of mind knowing that your bottom end will handle your goals with out any problem and not to mention you won't find a better deal than $759 with free shipping for forged pistons and steel rods!
Hit me up if you have any questions, I am always available at the office M-F.
P.S. Here is just one of my clients F22 bottom end that we have built for his killer street project. It features this same Bisimoto piston/rod combo along with our heavy duty wrist pin upgrade, pistons coatings and Golden Eagle sleeved block. This bottom end will easily handle 800+ WHP for track days and 600+ WHP for street use!
Old Nov 8, 2012 | 01:49 PM
bigbpatel's Avatar
Default Re: Bisimoto F22 H beam rod and 9.1:1 piston combo..thoughts? pros/cons?
I just bought them, thanks!
Old Nov 8, 2012 | 01:56 PM
Thanks buddy, I will get them shipped out ASAP. If you have any other questions, do not hesitate to ask.
buffgsr
Sep 18, 2007 05:02 PM
tdizz07
Feb 24, 2007 08:32 PM
COLORPROS
Oct 20, 2003 04:16 PM
Mr.FBR
Nov 9, 2001 06:01 AM
