Installation the Alarm security 2way ICBM-7071
Old Nov 7, 2012 | 10:32 AM
aliriza010's Avatar
Icon2 Installation the Alarm security 2way ICBM-7071
Hi
I have a Honda CR-V 2wd 2001 Manual Transmission
I bought ICBM-7071 2-way FM car alarm with LCD status display
and i want to install by-self.
I scanned manual pages that show diagram of wires with description.
you can click on link for see that manual
I want to know about these wires I don't know where should be connect if it's possible show me which color I should find in my car and where is it also if you have wiring guide summary for honda cr-v 2001 please send me
this is my first experience and thanks for support
1- Green / Black (-) 200mA Factory Disarm output
2- Green / white (-) 200mA Factory Rearm output
3- Yellow (+) Ignition of key cylinder (key on) input
4- Green (-) Door trigger input
5- Purple (+) Door Trigger input
6- Blue (-) 200mA Second Unlock(Passenger Unlock) output
7- purple / white, Tachometer input / Constant power input
8- black / white, (+) oil sensor input / Generator input
9- Grey / Black (+) / (-) wait-to-start input for Diesel
10- Blue / white (-) 200mA bypass output when remote start
also I don't know what kind diagram for door lock wiring i should use for my car model.
Link of manual ICBM-7071 2-way FM car alarm:
http://i48.tinypic.com/2aabhug.jpg
http://i49.tinypic.com/2gukqdj.jpg
http://i46.tinypic.com/714pcy.jpg
http://i45.tinypic.com/18j31u.jpg
http://i50.tinypic.com/xepd0y.jpg
Thanks a lot.
Old Nov 7, 2012 | 05:56 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Installation the Alarm security 2way ICBM-7071
Do yourself a favor and take that alarm back. You do not know the headache your about to have with that unit or the damage it can do to your car. You can get the wiring diagram for free at bulldog security.
Old Nov 16, 2012 | 05:55 PM
aliriza010's Avatar
thanks wrx-killer-Sti-eater
1- Green / Black (-) 200mA Factory Disarm output (for my car it doesn't factory disarm output N/A )
2- Green / white (-) 200mA Factory Rearm output (for my car it doesn't factory disarm output N/A )
3- Yellow (+) Ignition of key cylinder (key on) input ( I find this wire: i tested when i put in key in ignition and beeps alarmed i find that wire and i coneected this wire also)
4- Green (-) Door trigger input ( I find this wire also when door open and dome light is on i connected to that wire)
5- Purple (+) Door Trigger input (N/A I have just (-) trigger so i didn't connect this wire)
6- Blue (-) 200mA Second Unlock(Passenger Unlock) output ( i didn't find but i think i should connect this wire to centeral lock but i'm not sure because before i used that wire for lock)
7- purple / white, Tachometer input / Constant power input ( i connected this wire to Distributor (blule wire)
8- black / white, (+) oil sensor input / Generator input ( i didn't find this wire too)
9- Grey / Black (+) / (-) wait-to-start input for Diesel (my car is not Diesel so N/A)
10- Blue / white (-) 200mA bypass output when remote start ( i don't know about this wire )
my car is shift Manual Transmission 5 speed, in the diagram wrote Brown (+) Brake pedal input
i connected that wire to clutch wire when clutch go in down its show active and (+)
and also my car doesn't have ignition 2 I connected that wire to Accessory 2
and i don't connected Relay because really i confuse and i scared to cut wire
right now remote lock and unlock the all doors and flashing the lights when lock and unluck that's it no more (
shock sensor and LED not working without light
remote start not active yet
please help me and I'm so sorry if my English is not good
thanks for support
Old Nov 17, 2012 | 12:06 AM
Allready problems from the start. You will wake up with a burnt up starter or worse. That starter relay box will fail.
Old Nov 17, 2012 | 05:12 PM
Aau's Avatar
Aau
as far as remote start, u may need a bypass module(if ur key has a chip)
never worked with that alarm but i don't recomend someone installing a remote start unless they know what they are doing, as far as for finding the problem, there may be some setings and some wires that may not be hooked up rite, thats one of those things that ur better off having a shop install b/c there are dozens of things that could be the cause of them not working and they need to be properly tested to find the problem.
Old Aug 20, 2013 | 08:18 PM
honda.girl.1991's Avatar
Icon2 Re: Installation the Alarm security 2way ICBM-7071
I also have this alarm for my car, have not installed it yet but, after reading your post what is the down side of this alarm system, if you don't mind me asking.
Old Aug 21, 2013 | 11:45 AM
NVturbo's Avatar
O.G. triple O.G.
Flea market crap. Return it and get your money.....if you can.
nyvtec89
Audio / Security / Video
Aug 17, 2011 05:20 PM
menappi
19
Oct 13, 2006 11:57 AM
menappi
11
Oct 11, 2006 01:07 PM
accord91h22
May 31, 2005 05:15 AM
intezn
Aug 6, 2003 05:39 AM
