Can't get this plug out
Old Nov 7, 2012 | 08:27 AM
moaterboaink1ng's Avatar
Default Can't get this plug out
I need to install a new harness, so I'm taking my current one out. I cannot get this plug out to save my life. I don't want to brake it. I'm not sure what it is but it plugs right on the top of transmission. Am I just a little girl or what?
Old Nov 7, 2012 | 11:04 AM
oversteer_ms's Avatar
Default Re: Can't get this plug out
Back up light switch. They get hot and the rubber gets hardened and are almost impossible to get off without breaking. Just grab on to it with some pliers wiggle and pull. Worst case scenario is you have to reconnect it with some bullet connectors.
Just dont twist it!
Old Nov 7, 2012 | 11:26 AM
Ok. So I'll grab it with pliers at the base where the green wire is.
Old Nov 7, 2012 | 11:38 AM
No below that. The larger diameter part part of the plug.
Old Nov 7, 2012 | 11:39 AM
Old Nov 7, 2012 | 11:40 AM
Try and slide that boot up and it should pop off. The boot just kind of shrinks over the sensor.
Old Nov 7, 2012 | 01:07 PM
HondaPartsHero's Avatar
Technical Hero
Not sure what car this is but there should be connectors up the harness a bit that unplug
Old Nov 7, 2012 | 01:16 PM
Ok I'll try that when I get home. The car is a 90 civic with a d16y7. Not sure what harness I have in there though. If I can't get it off I'll probably just cut the wires and solder/ heatshrink to new harness.
Old Nov 7, 2012 | 01:19 PM
Actually your right. Maybe it doesnt unplug there. I was thinking in perspective of the oil pressure sensor. Same style.
Old Nov 7, 2012 | 01:31 PM
I wonder what would happen if I unscrewed it below where your arrows are. I could get a wrench in there.
Old Nov 7, 2012 | 01:34 PM
It would take the whole switch out. No biggie. I just cant remember now if it unplugs from the switch or not. If there is bullets connecting it up about 6-8 inches up just undo it there.
Or just unscrew the whole sensor.
Old Nov 7, 2012 | 01:36 PM
aristides's Avatar
Oh I had the same problem a week ago lol
I just got a thin flat head and popped it off :D
It didn't break
Old Nov 7, 2012 | 01:40 PM
A few inches up it just goes into the plastic of the harness. I'll get it up just didn't know if there was anything special about it. Thanks.
Old Nov 24, 2012 | 12:40 AM
Bwek951's Avatar
Spray some on pb blaster catalyst or wd40 and then grab it with pliers. Just yanked that one off the other day on my y7 and that was a knuckle buster
Old Nov 24, 2012 | 10:25 AM
fcm's Avatar
fcm
Old Fart
The back-up lights switch assembly DOES NOT unplug at the switch, it unplugs a few inches up the line, #8 it does unscrew from the transmission housing...
Grabbing the top of the switch with anything and twisting/turning/pulling will damage the switch.94
cloviskilla
Jan 14, 2011 07:40 PM
chinese acrobat
May 17, 2009 08:52 AM
CeoStatus0
Oct 24, 2007 09:44 PM
Apex i ITR
Apr 15, 2003 04:21 PM
