Tie Rod End
Old Nov 7, 2012 | 12:06 AM
Jdm Accords's Avatar
Default Tie Rod End
i accidentally remove the nut behind the tie rod end... and i already forget how many turn the tie rod ends when i want to install the new tie rod.... how many turn actually it suppose to be? forgive me for my bad english
Old Nov 7, 2012 | 02:14 AM
holmesnmanny's Avatar
Default Re: Tie Rod End
It's going to depend on your car, the tie-rod manufacturer. If I remember right, mine was 19, but I'm not sure. Really the best thing to do is get an alignment after you put it on.
Old Nov 8, 2012 | 04:04 AM
Thanks Holmesnmanny... gonna check it tomorrow...
Old Nov 9, 2012 | 09:04 AM
forted's Avatar
You could also put the steering wheel straight and line of the front tires straight. Look down the outside middle of the wheel and line it up to the rear tires. That will get you much closer than counting threads.
Smash03
Dec 11, 2007 11:01 AM
danteisme
Nov 15, 2007 05:46 AM
hinds90
Suspension & Brakes
14
Jun 18, 2007 11:05 PM
RacerBoy
Apr 1, 2003 07:20 AM
arcticblursx
Mar 27, 2003 05:55 PM
