1992 Accord Cruise Control
I can push the cruise control button but the light does not come on and the cruise control does not work. Is this most likely the cruise control main switch or control unit? This is a manual trans if that matters.
Using the black wire as the ground, the next wire over has 11/12 depending on whether the cruise switch in on or off. The next wire over has 11/12 all the time. The far right 2 red wires I can not get any voltage. This was all done with the car running.
Main switch is ok, if I'm following your description.
Next, check the brake light switch....also since this is a manual trans, be sure the "plug" on the clutch pedal - lower - is in place.
Ghettochild2600
Aug 19, 2016 10:14 AM
ophdehEEzY
Jun 26, 2003 05:12 AM
