2002 RSX heater core headache
Old Nov 6, 2012 | 08:40 AM
GarageMonster's Avatar
Default 2002 RSX heater core headache
Hi, Thanks for all replies in advance!!!
I just replaced a heater core in this 02 RSX now the SRS light is on, the fuel guage stopped working and the check engine light also. Idid everything correctly and have rechecked every electrical conector for bent pins ...etc.
I can't find anything obvious and I can't get a shcematic ele diagram.
Any help would be greatly apreciated.
Old Nov 7, 2012 | 06:47 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: 2002 RSX heater core headache
did you check the CEL? Why is that on? Also did you try an SRS scan?
Old Nov 9, 2012 | 04:18 PM
lazlong's Avatar
Check all your grounds again.
Old Dec 3, 2012 | 06:35 PM
TKATS_EF's Avatar
well on the fuel gauge check fuse no.9 (7.5A) in under-hood fusebox. and also check fuse no.10 (7.5A) in the under-dash fuse/relay box, then check ECM/PCM DTC(s). Troubleshoot and repair the causes of the DTC(s) -Diagnostic Trouble Codes-.
EgHatchy96
Feb 17, 2014 05:28 PM
onetimelife
Aug 3, 2013 08:30 AM
EJ8 GSR-T
Oct 23, 2004 02:06 PM
