Drag Cartel Billet K-Series Camshafts / Best Proven Cam Available / Stocking Dealer
Import DPS is an authorized, stocking Drag Cartel Camshaft Dealer. We have worked with the Drag Cartel team on a variety of setups including the Worlds Fastest K-Series in the World with El Freddy. Among the big cars, we have installed and tested tons of Drop In Cam and 2.2 Endurance setups on not only all motor car's, but also on Supercharged Applications. The quality of the camshaft and name backing them simply is unmatched. Don't take our word for it though, Drag Cartel Powered Car's own all the records!
*** Drag Cartel Drop In Camshafts - K Series Vtec Heads 3 Lobe - $995 ***
Works with Stock Springs and Retainers. Performs most efficiently with RBC or RRC Honda OEM Intake Manifold and 70mm Throttle Body. Great Camshaft for an entirely stock engine that is being daily driven and wants an added power gain. Most gains are on mid range with some peak power as well.
Click Here to Order DIC Camshafts - http://importdpsonline.com/drag_cart.../i-533199.aspx
*** Drag Cartel 2.2 Endurance Camshafts - K Series 3 Lobe Vtec Head - Just $995 ***
Works great on all K-Series Engines. Supercharged Applications love these camshafts. We have seen 20-25hp additional on Kraftwerks Powered Civic Si kits with these cams. Very great mid range and continuous power thru the top. Can be used on Stock 11:1 86mm Cranks however, 12.5:1 or higher yields best results. Needs to be used with Supertech SPRK-H1021D Spring and Retainer Kits, which are available for $299 More.
Click Here To Order - http://importdpsonline.com/drag_cart.../i-533200.aspx
*** Drag Cartel 4.5 Race Camshafts - K-Series Vtec 3 lobe - $1295 ***
Made for 99 or Bigger Cranks. 12.5:1 or higher compression. Serious all motor camshafts. Made for the hardcore K-Series Enthusiast. These camshafts will yield 300+ HP with the right combination of other parts. We have seen 320HP on a dynojet with these camshafts using E85, ASP Header, 99 K24 Crank with 12.5:1 compression. MUST use the Supertech SPRK-H1021D Kit to run efficiently. That kit is available for $199 when Camshafts are purchased.
Click Here to Order - http://importdpsonline.com/drag_cart.../i-533201.aspx
Camshafts are in stock along with Spring and Retainer Kits when needed right here in our Store. We are big gear heads when it comes to the K-Series Engine. All Drag Cartel Camshafts are Billet!! Use of a new Honda OEM Factory Type S Tensioner is recommended whenever your replacing a Camshaft on a K-Series Engine. We accept Visa, Mastercard, American Express and Discover Cards. Cash Pickups are also welcome! All PA Residents must pay 8% PA Sales Tax.
Thanks
Import DPS
www.importdpsonline.com
