Honda CR-V & Element 2WD & 4WD Element & CR-V
Struts/Ball Joints
Old Nov 5, 2012 | 10:42 AM
teamo's Avatar
Default Struts/Ball Joints
02 CRV EX. I am going to replace all four struts as well as the front lower ball joints. I think I have a good handle on doing it myself. All things being equal should I go with Monroe, KYB, or Gabriel struts? Should I also do the lower control arm bushings while I have it all apart? What size is the front axle nut? I have seen three different sizes while shopping for parts.
Old Nov 5, 2012 | 11:03 AM
teamo's Avatar
Default Re: Struts/Ball Joints
I was thinking of pressing the ball joints into the knuckles with one of those rented c clamp type from the auto parts store. I did see a couple of cheap presses at Harbor Freight Tools. One of them was a 20 ton and the other one was a 12 ton. Is the 12 ton press enough to do the ball joints and any other bushings that I might have to press or shoud I step it up to the 20 ton model?
Old Nov 7, 2012 | 05:45 PM
94EG8's Avatar
Seagull Management
If you aren't buying OEM shocks buy KYB.
Old Nov 7, 2012 | 06:00 PM
LDForget's Avatar
i run KYB's on my slammed CRV and it rides amazing.
Kevs02Accord
Nov 8, 2011 04:04 AM
MrViet
Jan 11, 2010 06:14 PM
89efhatchcrap
Suspension & Brakes
24
Feb 17, 2009 10:36 AM
Cabby89
Jul 31, 2007 08:06 PM
GruvyTune
Aug 10, 2004 11:30 PM
