Transmission reassembly steps
Old Nov 4, 2012 | 05:52 PM
lsturbo*'s Avatar
Default Transmission reassembly steps
Had to fix a hole in my type s transmission case, so basically took all the guts out, welded it, and putting everything back in the case. What steps do I need to follow as far as what gear to put it in, or where the shift forks need to be when reassembling? Is there only one way to put everything back together? I guess I am wondering what variables could go wrong when putting this back together....?
And how can I check that everything is back in right?
Old Nov 4, 2012 | 06:29 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: Transmission reassembly steps
wow this will go super bad trying to explain all the steps via internet like this.... you should download the helms manual PDF and read it carefully...
to check it spin it by hand and hope and pray
Old Nov 4, 2012 | 07:01 PM
lsturbo*'s Avatar
Got the helms. Followed it step by step. Didn't mention anything about noting what gear it was in when you removed anything....or to pay attention to shift fork position on reassembly. It says to reassemble everything. I know where the shift forks sit on the shaft assys, just didn't know if they need to be in a certain gear, like neutral or something when it all goes back together
Old Nov 10, 2012 | 09:18 AM
lsturbo*'s Avatar
Got it back together no problem. I guess I wasn't too clear on my question. I was concerned about what position the shift forks needed to be in when I but the case back together ( what gear) . But as it turns out it does not matter on assembly, since you index them all together when you reinstall the shift mechanism. Either way, all good and hopefully this helps someone down the road.
Uncle Seth
Feb 12, 2018 12:44 AM
Keith Coles
Honda CR-V & Element
Jun 16, 2014 10:17 AM
haiyter
May 3, 2007 07:08 AM
Mi2age
20
Feb 8, 2006 02:43 PM
b19coupe
Acura TL, RL & ZDX
14
Sep 12, 2003 05:20 PM
