99 Trans Question
Old Nov 4, 2012 | 04:15 PM
jpdocdave's Avatar
Default 99 Trans Question
So my 1990 Accord is going along great, I've had to replace a main relay, the Transmission Control Module, along with some other common stuff, this site was a huge help with the main relay, and tcm issues.
I'm buying a 1999 Accord for a smokin deal from a friend because it has no reverse. I'm a mechanic, and swapping the trans is no big deal, but are there any other things to check first. A quick web search shows a lot of these cars have this issue. Is it usually an internal failure, or are ther any common circutry or solenoid issues, or anything else?
I got my 90 Accord from a guy for cheap because he thought it needed a trans being in limp mode, and the TCM was the issue, I definitely want to check into this 99 before yanking the trans.
Thanks
Old Nov 5, 2012 | 08:51 AM
boosted95si's Avatar
Default Re: 99 Trans Question
i have the same problem with mine. have you found anything ?
Old Nov 5, 2012 | 08:58 AM
h22accordcoupe's Avatar
if you have alot of money i would get the h22 trans becuase of the lower gear ratio but if not then just go with standard f22
Old Dec 9, 2012 | 02:00 PM
jpdocdave's Avatar
For those interested it was the transmission. I talked to a trans guy and he said the fork wears out for reverse, and it needs to be rebuilt or replaced. I replaced the trans and working great. I also did the timing/balance belts, pullies, water pump, and front brakes. Nice little car now. Great driver.
Old Dec 9, 2012 | 04:15 PM
hondanacura's Avatar
I had a question about my transmission on 97 Civic also. They have a separate forum for that if you're interested:
Honda-Tech >
Honda and Acura Technical Forums> Transmission & Drivetrain
paintedair
Oct 21, 2015 07:25 PM
HOOT972
Mar 14, 2010 08:27 AM
Dave1821
Dec 8, 2009 08:32 PM
