203whp gsr full motor for sale MINT possible partout
FS Item(s) Description: LOCATED IN ONTARIO CANADA
selling my b18c1 thats fully built no corners cut, took the motor out of my integra and didnt want to take apart a motor that doesnt burn any oil and runs perfect, its in my daily and rather sell or part it out now then ruin it in the winter. the motor in my integra with a 3 inch exhaust made 202whp and 138tq tuned by tony at dmt and broken in by tony , in my ek with a restrictive ws2 2.38 inch exhaust it made 190whp and 130tq i have both tunes saved on my computer for hondata
HEAD
01 b18c1 head
ported head
supertech bronze valveguides on the exhaust side
skunk2 pro series valves, springs and retainers
skunk2 tuner cam gears
skunk2 pro1 cams
skunk2 intake mani port mached to tb
skunk2 68mm pro tb
hondata intake mani gasket with extended studs in the head
skunk2 vtec solenoid
skunk2 vtec solenoid cap
skunk2 oil cap
itr valvecover
skunk2 cam seal
vibrant timing belt tensioner
msd super conductor wires
skunk2 rad hoses
FUEL
aem black fuel rail
aem black fuel pressure regulator
id 1000cc injectors with evo style clips
BLOCK
wiseco pistons 81.5 11:5-12:1
manley rods
arp rod bolts
arp head studs
acl bearings/trust washers
cometic THICK headgasket i was sent the wrong one so slapped on this one because it was new and in stock, throw a thinner one on and will benefit
CLUTCH
act heavy duty pp
act 6 puck sprung
act street light flywheel
Electronics
hondata s300 version 2 in a p28 ecu
MACHINE WORK
all done at forest and forest in ayr
bore
hone
deck the block .10thou
install valve guides
resurface head/ hot tank
MISC
hasport eg dc mounts
itr throttle cable bought new from honda
all gaskets, thermostat, t belt, oil pump etc replaced with oem honda
motor has only had motul fluid inside it other than break in oil, runs very strong really hate to see it go but time to upgrade , im probably missing alot any questions feel free to ask, going to have it up for about a week if noone wants the whole motor ill part it out,
motor doesn't come with tranny, intake, wire harness and header
make me a reasonable offer! if its too low ill let you know if youre interested in certain parts let me know aswell and ull get first dibs on the partout
Asking Price:
pm me
ONTARIO CANADA
HEAD
01 b18c1 head
ported head
skunk2 pro1 cams
skunk2 68mm pro tb
skunk2 oil cap
itr valvecover
skunk2 cam seal
skunk2 rad hoses
FUEL
aem black fuel rail
BLOCK
manley rods
arp rod bolts
arp head studs
CLUTCH
act heavy duty pp
act 6 puck sprung
Electronics
MACHINE WORK
bore
hone
MISC
Asking Price:
pm me
ONTARIO CANADA
L.A.OutlawFWD
Apr 21, 2011 10:56 AM
