Honda Del Sol Garage SALE!
This is all I have left, IF YOU DO NOT SEE IT I DO NOT HAVE IT. Below is all that is left!
Pic of everything:
(forgot to take a pic of the rear speaker rings but I included the pic and info below)
[size=x-large]Close up pics of everything:[/size]
Back plastics that go beside the back bins on each side with the screws and clips $20 + ship.
Left and right rear speaker covers $30 +ship
Passenger side sail panel with screws $15 +ship
Driver and passenger side NON POWER side mirrors $50 + ship
Driver and Passenger side USDM Visors, comes with 4 grey screw covers and screws $30 + ship
2x 3rd break light, comes with screws and the red cap covers (have one busted tab on each, can use clear RTV to stick em back in). You could also use this as a break light delete and paint over them to match your sol! $15 + ship each
Dash harness = NO CUTS AND COMPLETE, attached at the center console and went up to the cluster and switches $40 + ship
Rear speaker brackets with bolts $50 +ship
Center console HVAC air vent $10 + ship
Del Sol Manual $10 + ship
2x Climate control units. Both units are missing the fan adjustment **** as well as the cap for the AC button, Not sure if either car had AC as the engine bays were pulled out. I know one of them just had the blank cap at one point but it got sold. $15 each + ship
Ebrake handle and bolts, if you buy an aftermarket ebrake handle cover you can use this one and then yours is still good. $15 +ship
Trunk lock cylinder with rod, perfect if you want to re key your trunk so you have one key for everything! $10 +ship
Trunk lid bumper to protect targa from hitting the trunk lid when in trunk $5 +ship
Del sol over the cluster switches, I have 2 of the harnesses and 1 defrost, 1 hazard and one block off (blank). $8 each or $15 for it all +ship
Switch pigtail harnesses $5 +ship or free with purchase of something else over $10.
Honda OEM Gas Cap $5 +ship
The metal pieces with bolts that your center console parts screw into on the frame $10 +ship
The cover for the trunk latch in the back with the screw to attach, I also have the clips that hold the hard plastic part on the rear carpet $10 +ship for it all.
Rear targa latch part that attaches to hold in the targa in the rear $10 +ship
The rear seal for the back window that goes from one side above the window to the other side $10 +ship
The bracket for the glove box $5+ship or free with purchase of something else that will fit in the same box.
Custom map light install (I never had a chance to complete). Uses a civic or integra map light. Cut perfect! $30+ ship
Let me know what you need! Buy more and I will make you a deal!
Pic of everything:
BUMP!
SOLD THE FOLLOWING ITEMS:
- Gas Cap
- The cover for the trunk latch in the back with the screw to attach, I also have the clips that hold the hard plastic part on the rear carpet
- The metal pieces with bolts that your center console parts screw into on the frame
- Dash harness
Above items SOLD!
- Gas Cap
- Dash harness
Above items SOLD!
Someone asked if the 3rd break lights were 100% functional. I just pulled my car apart and clipped each one in. Both 3rd break lights are 100% working condition and NO burnt out LED's.
Just wanted to add that!
should not take more than 20 min to install them both.
