EG Hatch - front of car seems loose, rattling when going over bumps
Old Nov 3, 2012 | 03:35 PM
cryingsuns's Avatar
Default EG Hatch - front of car seems loose, rattling when going over bumps
So when I'm driving and I go over bumps it seems like the front of my car is loose, kind of rattling. Mostly over small bumps. Like when there is cracks in the road or something. So intially I fixed the following stuff on my car to fix the problem:
Half-shafts
Diff(changed to LSD)
I've read a lot of stuff online, and it seems like I may need to change the engine mounts next. Any idea's, thoughts, or imput?
Thanks in advance.
Old Nov 3, 2012 | 03:45 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: EG Hatch question...
Man thats a hard one to figure out through a forum but I seen more then plenty of times a rattling over speed bumps or cracks in the road come from a loose heat shield or something with the exhaust... motor mounts will make a knocking sound more then rattling imo hope this helps some if you can give anymore detail that would be great
Old Nov 3, 2012 | 03:59 PM
cryingsuns's Avatar
It almost feels like my half shafts are loose but I just changed those over. It's not just sound I guess, but more of the whole front end feels like it's rattling. I have a B Series swap with EG6 mounts. Skunk2 Camber plates. I almost feel like I could jack up my car and shake my wheel and it would be loose, but I tried that. Everything seems solid but it's not.
Old Nov 3, 2012 | 04:28 PM
dirty19's Avatar
Ridin Dirty in Cali
Wheel bearings, Ball joints, LCA bushings....
Get her up in the air and start checking.
Old Nov 3, 2012 | 04:31 PM
CO671's Avatar
Start from the bottom up, check everything. What i'd do is lift the car safely on jackstands and just start carefully shaking things to see if there's unusual play.
1) Tires (12x6 and 9x3 check)
2) Wheels
3) Studs/Lugs
4) Wheel Bearing
5) Axles
6) Springs/Struts and that camber kit too
7) Tie-Rod
8) other bushings
9) exhaust
10) engine mounts
11) any thing else hanging or loose.
Old Nov 3, 2012 | 04:52 PM
cryingsuns's Avatar
Thanks, I'll check it out tomorrow and let you know how is go's.
jkalex05
Sep 17, 2012 05:09 AM
mxracer420
Oct 5, 2009 08:31 PM
DC5mike
11
Nov 9, 2007 07:04 PM
janarki
Aug 8, 2006 08:47 AM
tomlinson619
May 6, 2006 06:54 AM
