y8 to z6 swap VSS issues
OK. I searched for hours on here about vss issues. I swapped the engine about 6 months ago (y8 had 285,000...rip good friend). Got a z6 pretty cheap with 80,000. p28 ecu. All engine grounds are good. I put a new alternator in just because I am pretty sure the old one was stock.
My speedometer and odometer quit working about 4 years ago....well, it worked at times.....I would drive for 10 minutes and it would be on the whole time. Next day didnt work. Next day would work.
So, last night I put the new vss in, plug it in and take off down the road. Spedo doesn't work and the lights get dim and then bright, car ran rough....back and forth. I unhook plug everything is fine...except it throws a cel.
So I am assuming a short in the harness or something? Could it have anything to do with the swap?
I drive this car everyday and just want to make her a perfectly reliable car...not a bitchy bitch that gives me nothing but trouble.
I cleaned everything with contact cleaner. No cel light....no speedo either. Now can a faulty vss cause the speedo itself to go out? The needle bounces sometimes like it wants to work. About ready to give up on the speedo.
crxzcracer
Sep 23, 2007 07:24 PM
