Swap questions PLZ help,
Hey honda tech am doing my first swapam a noob, got the motor in everything wiered up but i bought some new axles do i have to lube them or anything before i put them in? Also i need help how to put the shift linkage pin(bitch pin) back in, also other question is the front lower sway bar that goes into the hole i believe into the from what size not is that also what size boltz and nutz are that belong to the shock tower from the bottom(where it connects the control arm)
You do not have to lube the axles before you put them in. And all you have to do is line up the hole on the shift linkage to the hole on the shift rod coming out of the transmission and hammer the "bitch pin" back in, are you having trouble doing that?
I don't really understand what you're saying about the sway bar and I think you're referring to the front fork, and that has a size 17 bolt and a 17 nut on the other side of it that holds it onto the control arm.
