Updated parts list for 5 lug conversion---11.8 inch rotors
Ok I just figured out how to put bigger stock honda/acura parts on a 5 lug conversion.
95 accord lx
Rear
Ex rear hubs.
01 prelude rear bearings.
94-97 accord caliper bracket.
03 rsx rotors.
03 rsx calipers.
and almost any year honda/acura rear pad.
Front
97 odyssey front knuckles.
Then press out the hub out of the bearing, then knock out all of the wheel studs.
Take the hub to a machine shop or put it on a brake lathe like it did. 1st ones look like crap but got the job done.
Machine the outer lip of the hub down I didn't measure to what size.
But you want it to fit the center of raybestos brake rotor 96795. Which fits newer model accords and I think 04-12 acura tsx.
Then finished it off with I believe 04-12 from what my book said acura tsx calipers, brackets and pads.
RC11119NS
RC11120NS
Rotors are 11.8 inch diameter and 1.100 inches thick.
95 accord lx
Rear
Ex rear hubs.
03 rsx rotors.
03 rsx calipers.
Front
RC11119NS
RC11120NS
Or, you can get the 99-04 front rotors for the Acura RL and skip a lot of steps. The RL rotors fit the Odyssey hubs, are 300mm in diameter (11.8") and are 28mm thick. The RL caliper brackets will work with NSX calipers, Legend GS calipers, or (of course) the ones for the 99-04 RL. The Legend and RL calipers have the same sq mm of piston area (same as most Honda and Acura single piston front calipers), the NSX has somewhat less. I have the NSX setup on mine and I love it.
97 accord se
Feb 1, 2006 01:32 AM
