►► November - December | All Motor Classifieds | FS & WTB ◄◄
**Rules**
- Each post must be started with FS OR WTB
- Do not reply or quote posts in this thread, PM for all questions
- Please do not post/type in ALL CAPS
What you CAN post in this thread:
- Engines/Any engine component
- Transmissions/Any drivetrain parts
- Electrical components such as ECU'S, ETC
What you CANNOT post in this thread
- No vehicles for sale
- No wheels
- No Brake or Suspension components
- No interior/exterior parts
- NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
Any violations of these basic rules, and your post may be deleted and lose participation in this thread.
- No wheels
TB Motorworx B16 Head that came off his Famous CRX that went 10.40s $1000
Another Ported B16 Head by Compression Kings with Ferrea Flat Face Valves & Welded Chambers $550
JG B18 Sleeved Block 86mm Needs rehone .25 over $450
Eagle 95mm Stroker Crank $350
Eagle LS/B20 Rods w/ARP 2000 Bolts @260
B16 Hydro Transmission w/Quaife LSD and 4.4 Final Drive $1200
4 NOS Annular Foggers w/Bungs and Induction-Solutions Burst Panel $200
Quickest Response Text or Call me @ 951-570-7983
No 1000 question text, no flakes, NO TRADES
Cash Only
Thank you for your time
-Dan
Cash Only
-Dan
**::Attention, Email is key, joone.nijjar@gmail.com:**
Hello Folks, It has come to that day that I am actually parting out my racecar. I thought this day would never come but unfortunately it has. Here is a chance for you to pick up some quality parts for great pricing. Everything has low miles on it (between 20-30 total miles) and was kept in exceptional condition. Take a look and feel free to inquire.
p.s. I will keep this thread up to date whenever I sell something, so far stuff has been moving. Feel free to make an offer and if it works, I will get the stuff ready to ship. Thanks in advance.
* ITR Shift Linkage with a BNIB Energy Suspension bushing kit included
* MFactory B16 LSD with bearings
* 4.9 Gear-X Final Drive kit for B16 trans
* Skunk2 Oil Cap
* H22 Timing Tension Conversion Complete
* JDM h22 Distributor wired for MSD external Coil. Includes MSD spark plug wires.
* H22 ARP head stud Kit with Lube, used
* ::Low Miles:: H22 oil pump bought brand new, Pro-Drive high pressure Oil Pump Gear installed, Kiazenspeed Balance Shaft Eliminator Kit installed.
* 1996 JDM H22a closed deck block Sleeved with Darton replacement sleeves, 89mm bore.
* ID725 injectors for a Honda K series engine with low miles as well.
* Skunk2 K series 74mm TB with sensors and IAC Block off plate.
* Golden Eagle Oil Sandwich Plate
* Momo Monte Carlo Steering Wheel with Mugen Horn Button and NRG Quick Release as a set.
* Seat Rails & Sliders for Driver and Passenger Side, EG/DC. Used with Side Mount Seats.
* Autometer Oil Pressure Gauge with Sender Unit, Autometer Water Temp Gauge with Sender Unit, and carbon Fiber bezel with slot for one more gauge. Fits into Radio din or Climate Control Slot on EG.
****SOLD to a Fellow H-T'er**** Thanks "DrCRX"
* H22 Carrillo Rods
* 89mm 13.5:1 CP pistons with relocated wrist pin for use with H22 rods and H23 crank. (20-30 miles tops!!!)
****SOLD to a Fellow H-T'er**** Thanks "92frostwhtdb2"
* PLX Wideband with Gauge.
* Hydro B series Clutchmasters twin disc fx700 Clutch
* DSS level 2.9 B-series axles.
****SOLD to a Fellow H-T'er**** Thanks "92siracer"
* H22 Valve Cover properly baffled and vented. Only releases pressure, not a bunch of oil...
* Custom h2b Scattershield powdercoated Silver
****SOLD to a Fellow H-T'er**** Thanks "Souler"
* Billet Aluminum coolant overflow catch can.
* MSD SS blaster coil
* MSD Digital 6 Ignition System
****SOLD to a Fellow H-T'er**** Thanks "richboy84"
* B&R Catch Can with lines
****SOLD to a Fellow H-T'er**** Thanks "H2BJON"
* Skunk2 k20 Fuel Rail with -6 fitting for fuel in
****SOLD to a Fellow H-T'er**** Thanks "MyLilCivic"
* SSR stainless steel 4-1 race header with bottom exit megaphone for an h2b with an h22 head.
****SOLD to a Fellow H-T'er**** Thanks "weedstnr"
* KStuned h2b Oilpan with pick up and dipstick, no dings/dents/damage.
****SOLD to a Fellow H-T'er**** Thanks "fliplude95"
* Blox Racing EG/DC Traction Bar
* XS FPR with -6 fittings in black.
* H to D series alternator relocator bracket with Alternator and belt
* h22 Euro-R Single Row Crank Pulley
****SOLD to a Fellow H-T'er**** Thanks "lovitalracer"
* Bogart Pro-4 wheels and tires. (car always rested on Jackstands) 4x100
Fr: 24.5x8.5x13 M&H slicks on 13x8 wheels (Back spacing clears brakes as large as Integra GSR/LS/RS/GS
Rr: 24.5x3.6x13 M&H skinnies
****SOLD****
* STR70mm B/H/D TB with sensors-
****SOLD****
* Skunk2 H22 Pro series stage 3 Camshafts**
* Skunk2 H22 Pro Series Cam Gears**
* DNR Ported h22 Cylinder head, includes SKunk2 Valve Train and Supertech Flat Valves.**
Email is the key: joone.nijjar@gmail.com
* Skunk2 Oil Cap
* H22 Carrillo Rods
****SOLD****
****SOLD****
fs msd billet distributor part number 8488 comes with coil, wires, sci ignition box, msd 2step not parting out used for a month then state reffed never put back in the ignition box is carb legal located bay area ca still have some of the original paperworrk no trades open to offers please text 650-219-5553 for pictures thanks
WTT Blox type B cams for b16/GSR for Blox Type c or Blox HSL Cams for a B16/GSR. Or will Sell the Blox Type B's for $350 shipped. They only have 20 miles on them.
for sale:b16/type r twm 50mm ITB's 1000 bucks plus shipping. less than 1500 miles on them. comes with everything you need to put them on your car. new hondata gasket and throttle cable too.
located in va beach va pm me for any other questions.
FS: NEW Eagle part #1837401772lw B-series stroker crankshaft. Time to move on, I've had this for awhile in hopes of doing a all motor build but plans have changed. New In the box NEVER used!!! $500.00
http://www.eaglerod.com/index.php?op...d=21&Itemid=32
CP Pistons Eagle H-Beam Rods CRV B20B B20Z Integra LS B18A B18B 12.5:1 84mm 780obo brand new only open boxes to get pictures
PLM Toda Replica headers never used 350+shipping
skunk2 adjustable cam gears for b series silver 120
skunk2 70mm billet throttle body 180
please text me at 7816062829 if interested
Fuel Lab Mini FPR with BR Fitting Fuel line mounting kit. Direct fit for AEM Fuel rails. I paid over 260 for this and an high pressure spring. $220 asking price. All new but I did use the one line for my 044 setup . Located in York, Pa. This is for eg, dc, ek.
the reason im posting in here is because im looking for quality cams, bolt ons(tb, im, header), tuning software(s300, demon, etc.) for b16.
FS: Modified F23 rods with ARP rod bolts & BNIB 87.25mm S2K Mahle Gold pistons. Designed as an h-series stroker kit, but my build went a different direction. You just need an f23 crank and an h-series block with 55mm mains and you've got a nice 2300cc, 12:1 street monster. $600.
Extensively modified Honda F23 rods: custom ARP rod bolts, 23mm wrist pin bushings, forging marks ground off, professionally re-shotpeened, and balanced (end-balanced and set matched)
Mahle Gold series S2K (F20C/F22C) pistons. 87.25mm, high comp. Also includes custom light-weight wrist pins (86g vs 110g). These are BNIB, never installed.
WTB: 16, 8x50mm cam cap bolts (black 12mm head bolts that hold the cam caps down) I do not need the studs that poke through the valve cover.
Must be the BLACK version
Making room for new project everything must go Text for more info on parts 316-299-9469
$1600=
GSR cams
Full Portflow race head
Dual Vented Valve cover and catch can
Complete Ferrea Valvetrain with Flat Valves
BWR cam gears
Pending $500=
BBK Intake Manifold with 70mm TB
STR fuel rail with Hondata IM gasket
$350=
RAGE Big Tube Tri Y Header with Blox text pipe
$150=
OBD1 Dizzy with MSD cap, coil and wires
Pending $2450
AEBS T sleeves and O-ringed
AEBS Headstuds
CP Pistons 11:1 comp.
Eagle H Beam rods with ARP bolts
Mirco Polished Crankshaft
Type R water and oil pump
ARP main studs
ACL race bearings
Rotating Assembley is all Balanced and Blueprinted
$1100=
CTR Tranny 4.4 final drive with LSD
$450
ACT Xtreme 6 puc, Pressure Plate, and Lighten Fly
$100=
Iceman Headlight scoop EG
$550
Innovative B series to EF mounts and Shiftlinkage
Hasport Cable to Hydro mount conversion
Skunk2 Weighted shift **** and duel bend shifter
Stock axles
$550
Obd0 to obd1 conversion harness
Hondata S300 in P28 ecu
$350=
3" exhaust with Apexi N1 muffler
$1600=
GSR cams
BWR cam gears
Pending $500=
$350=
$150=
Pending $2450
AEBS Headstuds
ARP main studs
ACL race bearings
$1100=
$450
$100=
$550
Stock axles
$550
$350=
