1990 acura integra ls vtec
I was driving fine stop at the store came back no it's just turns over check engine light stays on but ecu dosent flash when turn into acc main relay dosent click put on a new no sound from it out of no where this happen
firstly, check/clean the thermostat housing ground.
if that's good, you need to check at the ecm for power and ground.
you should have 2 powers, one constant, and one keyed. and i believe 3 grounds. find a pin out for your ecm connectors and check for the powers and grounds
It's nice when it's something else that wasn't told to you. Open in charging system is an open to startin and getting power. KISS keep it simple stupid El
lowlight
Dec 3, 2003 03:28 PM
