2006 or 2007 4-cyl. Accord Sedan Brake issue
Those who have a 4-cyl. sedan please comment on the braking for the 2006 or 2007 years. Is the braking good? Any complaints??
Theyre really good when I had mine, only problem I had was the pads seem to wear pretty fast so make sure you get some good quality one even if it mean a dollar or two more
Thanks for the response. So, the overall opinion of the brakes on the 2006-2007 accords is favorable? Are Honda pads considered the best? Any other comments is appreciated.
As a past owner of a 2006 I4, I didn't felt any weakness in the system.
The only thing I had to get used to was that the (G7) Accord had become a bigger and heavier car. That took about 2 weeks to get used to.
So I guess the braking was good on the 2006/2007 accord I4 cars. I'm thinking on buying a 2006 accord I4 soon, and the only negative issue from Consumer Reports was the brake area on these two years. Any other comments is appreciated.
After-market upgrades are cheap for rotors and pads. My 08 coupe had the rear calliper pins (bolts) reversed from the factory which increased pad wear, there is a service bulletin on this but not sure if it affects the 06/07 models. nice cars, good luck with the purchase.
hondatech2000
Dec 1, 2006 07:16 PM
accrd01
Sep 16, 2003 08:46 PM
