!!! HELP w/ AXLE REMOVAL on LSD tranny!!!!!
Old Nov 1, 2012 | 04:38 PM
EK_HATCHBACK's Avatar
Default !!! HELP w/ AXLE REMOVAL on LSD tranny!!!!!
I have a LSD/ LS tranny on my b20 in my 97 ek hatch.. I have an axle seal leak on the passenger side. I tried prying it out like I do with non-LSD trannies and it wont budge. I've searched and a lot of people are saying that I'm going to have to break my axle to tip to get it out.!!???!?! Some say I'm going to have to pull the tranny out..?? I just want to know if there is a way to not break my axle or pull my tranny out to change my seal..???? Any help or suggestion is appreciated. Thanks
Old Nov 1, 2012 | 05:42 PM
92lxsleeper's Avatar
Default Re: !!! HELP w/ AXLE REMOVAL on LSD tranny!!!!!
just pull. its the same axles
Old Nov 1, 2012 | 06:05 PM
dirty19's Avatar
Ridin Dirty in Cali
prybar wrapped in a rag with just a hair of presure ... always separates the most stubborn of axels from the tranny.
Old Nov 1, 2012 | 06:06 PM
I have a buddy coming over tomorrow and Im going to have him pull while I pry the axle from the tranny. lets hope that works. but if anyone else has any other suggestions I greatly appreciate it.
Old Nov 1, 2012 | 06:07 PM
doood's Avatar
been there done that
open up a can of M.A.N
Old Nov 1, 2012 | 06:10 PM
civicguy395's Avatar
use a good slide hammer with a chain wrap the chain around the axle cup and start hammering anybody that does any kind of body work should have one
Old Nov 1, 2012 | 08:21 PM
thanks for the suggestions. I will try everything and whatever works for me tomorrow ill keep you guys posted.
Old Nov 2, 2012 | 06:14 AM
sde780's Avatar
Hammer a flathead in the space between the axle cup and seal, it should pop right out. Hammer it in towards the middle of the seal, not in a prying manner.
Old Nov 2, 2012 | 06:48 AM
strategy400's Avatar
Use 2 screwdrivers at 180 degrees from each other (one on each side) so the axle isn't being cocked to one side as much. Use the two screwdrivers to wiggle it out. Be careful it doesn't fall in your face. Maybe tie a wire loop to catch it. Also, I have read in the Helm manual that a worn differential/pinion shaft will cause the axles to become stuck in the trans.
Old Nov 5, 2012 | 05:20 AM
I got it out with a pry bar. I had to come from the top to do it.
im glad I didn't listen to the others that told me I had to take out tranny or that I had break an axle.
Old Nov 5, 2012 | 08:24 AM
edd805's Avatar
lmao
my axle was the same when i changed it on my lsd there a real bit** sometimes good you got it
turboef90
Transmission & Drivetrain
Sep 8, 2014 05:52 PM
laziebun
15
Aug 19, 2008 11:42 AM
eddiedeader
Dec 8, 2006 11:32 AM
90civSi
25
Jan 16, 2006 03:35 PM
TurBoTeG
Aug 13, 2005 02:33 PM
