Anyone know what this is???
Old Nov 1, 2012 | 11:44 AM
ed6inms's Avatar
Default Anyone know what this is???
Note: THE PIC IS UPSIDE DOWN BECAUSE OF MY PHONE BUT IT WAS TAKEN FROM THE TOP VIEW, LEFT OF STEERING WHEEL WITH THE DASH OFF.
Old Nov 1, 2012 | 12:17 PM
kyden's Avatar
Default Re: Anyone know what this is???
clutch switch?
Old Nov 2, 2012 | 01:55 AM
oversteer_ms's Avatar
Your picture does no justice on location, but the part im looking at is either a clutch switch or a cruise control shutoff switch. Both look identical and are right next to eachother if you have cruise control.
The clutch switch tells the car your clutch pedal is engaged and will allow the engine to start/turn over.
And the cruise control shutoff switch is pretty self explanatory, in a manual transmission if you engage the clutch pedal when your cruise control is on, it will shut off.
Old Nov 3, 2012 | 08:34 AM
fcm's Avatar
fcm
Old Fart
MM&Y of car and trim level would help. 94
Old Nov 7, 2012 | 12:13 AM
ed6inms's Avatar
91 civic hb dx. It is an AT now. used to be a MT but last owner swapped. he was a preacher. The clutch os still there but the cable isn't hooked up. I was wondering what plugs into this socket. ill get a better pic in the morning.
Old Nov 7, 2012 | 04:45 AM
fcm's Avatar
fcm
Old Fart
I am guessing it is the CIS, [clutch interlock switch] most likely it is unplugged and the plug jumped to allow starting, kind of depends on how the swap was done, if a dash harness for an automatic was installed so a neutral safety switch, [A/T gear position switch] could be wired, there would be no plug for the CIS. 94
Old Nov 7, 2012 | 02:48 PM
marley4us's Avatar
CIS
Old Nov 7, 2012 | 09:00 PM
dapimp1814's Avatar
Yup wat they said not important if u r automatic only for manual cars.
Old Nov 8, 2012 | 12:16 AM
Case closed.
Old Nov 24, 2012 | 12:43 AM
Bwek951's Avatar
Clutch switch just wasn't removed when swap
happened. Unless your OCD about it being there no worried man
Bubezzy
Dec 3, 2017 03:14 PM
fryman
Sep 28, 2011 05:47 AM
efyou
Oct 9, 2007 01:54 PM
binarypunk
Sep 24, 2007 06:04 PM
