PARTS LIQUIDATION SALE
Asking/Offering Price: below
Email Address/Phone Number (optional): PM only
Zip Code: 64118/gladstone mo
Pics: below
shipping will be added to the prices listed below. i charge EXACT cost to ship.
Item Description:
2001 GSR head - freshly rebuilt with new seals and new valves. has itr dual spring setup on both intake and exhaust. includes vtec solenoid. - $600 PENDING
http://img.techpowerup.org/121031/Capture525.jpg
DOHC VTEC valve cover - $75
ARP head studs - torqed 3 times. - $80
http://img.techpowerup.org/121031/Capture526.jpg
blox gsr intake manifold - brand new. never been ran - $150
AEM fuel rail - $80
Holley 70mm throttle body - $140
JDM B20 bottom end - dissassembled and cleaned. - $400
http://img.techpowerup.org/121031/Capture523.jpg
http://img.techpowerup.org/121031/Capture524.jpg
hondata intake gasket for gsr - $40
http://img.techpowerup.org/121031/Capture522.jpg
full set of GSR belts - ps, ac, alt. never used. - $20
4 piston BIG BRAKE calipers - you'll have to make brackets to mount these but they will work on almost any car. fabbing up some brackets for my crv right now. uses 11.5-12.5inch rotors. - $120 pair
http://img.techpowerup.org/121029/Capture518.jpg
http://img.techpowerup.org/121029/Capture519.jpg
ECUs, 2x p28 and 5x p06 - $90/$30
http://img.techpowerup.org/121018/Capture502.jpg
http://img.techpowerup.org/121031/Capture520.jpg
grey EK factory mats, full set for coupe, 4dr, or hatch - $30 set or will sell individuals for $8
http://img.techpowerup.org/121018/Capture503.jpg
http://img.techpowerup.org/121018/Capture504.jpg
civic VX head, intake mani(complete) - comes with EGR, injectors(vx only), tb, all sensors. head was JUST rebuilt with new seals and cleaned up VERY well. makes for 11.5/1 compression on z6/y8 bottom and capable of 60mpg. - $225
http://img.techpowerup.org/121018/Capture506.jpg
http://img.techpowerup.org/121018/Capture507.jpg
http://img.techpowerup.org/121018/Capture508.jpg
civic VX manual trans - HIGH gears(good for mpg, 80mph@3200rpm in 4th, 110 in 5th@4200rpm) also good for turbo D or turbo h2d setups - $200
CRV MANUAL CLUSTER(RARE) - WORKS IN EKs - $80
http://img.techpowerup.org/121018/Capture509.jpg
EG factory fogs - $40
http://img.techpowerup.org/121018/Capture510.jpg
2x IACV - $20 each
http://img.techpowerup.org/121018/Capture511.jpg
66-68mm honda centercaps - off an odyssey/pilot/etc. - $15 all 4
http://img.techpowerup.org/121018/Capture512.jpg
1st gen ITR intake cam - $75
http://img.techpowerup.org/121018/Capture515.jpg
b series vtec dizzy obd1 - $80
http://img.techpowerup.org/121018/Capture513.jpg
red EK 96-98 hood - $40
http://img.techpowerup.org/121018/Capture514.jpg
TRADES-
k swap parts
wideband setup
I WILL MAKE A PACKAGE DEAL ON THE VX conversion stuff... and IF and ONLY IF someone is DYING to get the WHOLE VX package i have the P07 ECU as well for $100. WILL NOT SELL UNLESS YOU BUY THE PACKAGE.
Pics: below
Item Description:
AEM fuel rail - $80
2x IACV - $20 each
TRADES-
k swap parts
wideband setup
NOCOASTcoupe247
Texas -OK -LA (Sales)
Sep 4, 2013 06:59 PM
Hatchorama
May 25, 2008 02:10 PM
