HELP!!! oil presure switch B20/vtec
Old Oct 31, 2012 | 12:43 PM
TRUCHONIC's Avatar
Default HELP!!! oil presure switch B20/vtec
hi guys i'm new on the forum also i'm a noob with b series Vtec and i bought a Acura B20 Vtec and there is alot of stuff that i don't know if they did right also the oil pressure switch its not connected i found a cable by the fire wall in front of the steering wheel i think is coming from the ecu (of course) also the ecu is a p06 but i think the last owner chipped
this is the ecu
and this is the oil pressure switch and the cable that i found
i don't know if i need to connect this one like that
i found this cable over here with this connector
and this is the jumper
well guys let me know cuz i need this car for the next week let me know if it's ok or if you need more pictures or a need to change something thanks
Old Nov 1, 2012 | 07:28 AM
kyden's Avatar
Default Re: HELP!!! oil presure switch B20/vtec
vtec pressure switch can be disabled in the ecu.
what is wrong with the car?
Old Nov 1, 2012 | 11:35 AM
TRUCHONIC's Avatar
i can't pass the 5000 rpm and the car have lack of power (slow car)
Old Nov 1, 2012 | 11:55 AM
kyden's Avatar
i assume you have a check engine light on? pull the code.
Old Nov 1, 2012 | 12:56 PM
TRUCHONIC's Avatar
no i don't have a check engine light, i just bought this car and im not sure if the last owner chip the ecu and the tune it
Kidd Dougie
May 24, 2018 09:55 PM
zCivic
Apr 21, 2007 12:25 PM
jdmsiR20
35
Apr 3, 2005 01:32 AM
I LOVE MY EF9
Jan 19, 2004 12:59 AM
b18c-93
Jan 7, 2002 09:25 PM
