o2 sensor for JDM B16A Second Gen
Old Oct 31, 2012 | 10:49 AM
Silversubie's Avatar
Default o2 sensor for JDM B16A Second Gen
Hey guys,
I am in need of an o2 sensor for my JDM B16A. It is in a 95 Honda Civic EX coupe, so I need to know what vehicle I can give to the parts store for them to pick out the correct o2 sensor. Would it be a 99-00 Civic Si?
Old Oct 31, 2012 | 10:54 AM
egsleepercivic's Avatar
Default Re: o2 sensor for JDM B16A Second Gen
use the one for the 95 ex, get either NGK or Denso and avoid bosch or anyone that you have to splice, you can get denso oem replacements that plug in directly for 35-40 on amazon
Denso OE Identical Oxygen Sensor
SKU: #234-4099
ITEM: #DEN234-4099
part# from sparkplugs.com
Old Oct 31, 2012 | 10:59 AM
civicguy395's Avatar
if you do get a bosch the color code is car green white black black connect both white wires to the 2 black wires tie the gray to the green wire and the black wire to the white wire
Old Oct 31, 2012 | 12:17 PM
Thanks guys,
So that denso one will plug right in correct?
This the right one?
Amazon Amazon
Old Oct 31, 2012 | 01:22 PM
looks right to me if it the same one as this
Amazon Amazon
Old Jun 5, 2013 | 05:49 PM
gdneon's Avatar
Hi!
I've plugged Denso 234-4011 in my civic eg6 jdm.
Ecu sometimes shows error №1 (oxygen sensor). Mostly when i'm braking by the engine.
Did anyone know why?
Old Jun 6, 2013 | 05:05 AM
sleepyaccord96's Avatar
but if his o2 sensor is located under the car(meaning his exhaust manifold OR header has the o2 bung Under the car on the downpipe...then a 95 stock ex o2 will no reach...
Get one with a longer harness try 92 95 prelude or 94 95 accord.
davidcrx89
Honda Civic (2001 - 2005)
Jan 5, 2007 07:09 PM
groundedcivic91
11
Nov 4, 2004 02:01 AM
shadykit
Oct 11, 2004 03:53 PM
Driven
11
Aug 30, 2004 08:35 PM
