02 Civic LX: tranny drain and refill .. vs tranny flush?
Just looking at my spreadsheet which I keep track of on maintenance. Back in June 17 2010 (146615 km), my car had a tranny fluid change (it was just a drain and refill i believed). I have it noted down that the next tranny fluid change would be 194615 kms or on June 17 2012.
What's the concensus regarding the cheaper drain and refill versus a full flush?
You should never force material through your transmission. It can only cause more problems then currently present.
You should never "flush" a transmission. It should always be drain and re-fill.
You should be fine with a drain and fill once a year or every 20,000-30,000 miles. Honda recommends replacing all the fluid at 120,000 but, I would be very hesitant to do that as these 7th gen auto transmissions tend to not like that very much.
i also had my 04 machine flushed when i first bought it at 80,000 miles because 2nd to third had a rough shift. after the flush the rough shifting stopped completely. now i only do a single drain and fill not 3 every 10,000 miles.
it is well know that the auto transmissions are faulty. main reason being the internal mesh filter is to fine of a mesh leading to it becoming clogged and cutting off oil pressure damaging clutch packs. thats why i had mine flushed disregarding hondas recommendation. my car is still running strong with no trans problems going on 150,000 miles.
Yes, I am referring to the transmission strainer. After looking at a few diagrams online it does not appear that it is as easy as in most domestic cars.
faster Type R
Honda Civic (2006 - 2015)
Nov 11, 2009 04:12 AM
mikeintegra93
Jan 9, 2009 04:12 PM
Hondapreludeg
May 16, 2008 01:21 PM
Elwuudz
Jan 15, 2006 07:54 PM
