LC-1 on ectune shooting way lean
Old Oct 30, 2012 | 05:30 PM
tales sol's Avatar
Default LC-1 on ectune shooting way lean
As the title says, My lc-1 keeps shooting to 5v all the way lean once over around 7k.
It reads fine at idle, cruise and part throttle, only happens when at WOT and higher rpm.
Sensor is only a couple of weeks old too.
Anyone had the same problem or have any ideas?
Old Nov 9, 2012 | 12:07 AM
swordofdoom's Avatar
Default Re: LC-1 on ectune shooting way lean
Have you calibrated your new sensor?
Old Nov 9, 2012 | 04:53 PM
xenocron's Avatar
Most likely a leak in your exhaust just before where the sensor is placed...
Old Nov 9, 2012 | 05:14 PM
josephcmiller2's Avatar
When I first installed mine I had bogus readings from too much electrical noise. After moving the LC1 away from some wires it was fine.
Posted from Honda-tech.com App for Android
Old Nov 17, 2012 | 12:14 PM
VegasInvasion's Avatar
I'm Huge In Japan
and/or your injectors are maxed out.
especially at high RPM, you could have poor grounding. clean all your ground connections, even if it doesn't solve the problem it's smart to do.
Old Nov 17, 2012 | 12:18 PM
GhostAccord's Avatar
Is this on a stock engine or an engine with mods that require tuning? What have you done to the engine aside from adding a wideband sensor?
garnet
Jun 28, 2014 05:20 PM
xfrankix2
12
Sep 12, 2007 08:10 PM
puk
10
Jul 21, 2006 03:59 PM
SIK IN DA HED
Nov 21, 2002 03:21 PM
