Agressive wheel setup.
Old Oct 30, 2012 | 04:07 PM
Tenassi's Avatar
Icon3 Agressive wheel setup.
I'd like to know what would be the most agressive wheel setup that I can have without rolling the fenders on a 2003 Honda Civic Coupe? My brother has a 2002 Volkswagen Jetta TDI and he has 17X 9.5 Corvette wheels and he did not have to pull the fenders and it rubs a tiny bit but I guess it's fine. What do you suggest me to go for? Let me know. Thanks.
Old Oct 30, 2012 | 04:45 PM
toyomatt84's Avatar
Sanji
Default Re: Agressive wheel setup.
Are you running any negative camber?
If not, you're looking at about a +32 for a 7" wide wheel, with properly sized tires.
Old Oct 30, 2012 | 04:57 PM
Tenassi's Avatar
I'm willing to run a bit of negative camber in order to fit the most agressive wheels.
Old Oct 30, 2012 | 04:58 PM
lowlife9's Avatar
hellaflush bro.
Old Oct 30, 2012 | 05:04 PM
Tenassi's Avatar
Originally Posted by lowlife9
hellaflush bro.
http://custompinoyrides.com/2010/06/...be-hellaflush/
Old Oct 30, 2012 | 07:13 PM
toyomatt84's Avatar
Sanji
Well, without doing any metal work... you're not going to fit much of an "aggressive wheel". The rear quarter panels are angled in such a way, to limit space for wheels. And, if that weren't a big enough problem, the front fenders have larger tabs for your fender liners that also limit how big of a wheel you can run.
Even with 3 degrees of negative camber, you're only going to gain 15 or so mm of clearance room. So, you're looking at maybe a +17 with a 7" wide wheel and properly sized tires.
Old Oct 31, 2012 | 07:32 AM
J-R559's Avatar
i've seen this around so i want to know exactly i how i can get 19s or 20s to fit my 02 civic sedan?. like what exactly is needed to do.
Old Oct 31, 2012 | 02:57 PM
toyomatt84's Avatar
Sanji
Sacrifice your personal safety, ride quality, fuel economy, and overall car functionality.
CWBETB
Apr 25, 2012 02:47 PM
JayTee91
Jan 31, 2012 08:49 PM
Boostn B20
May 1, 2009 05:31 AM
De_tour
Dec 28, 2005 07:00 PM
ntt
Oct 2, 2002 12:27 AM
