Oil under distributor
Hello guys,
been almost one year since i can see some oil under the distributor (b16 engine) couple of days i replaced the distributor o ring but still some oil is there!!
I know there is an internal seal, but i hear that it need some professional labor
any help ?
any help ?
The distributor carries two seals a inner and an outer seal, most likely it leaking from the inner seal, you will need to remove the distributor cap, then remove the distributor compeltly from the engine, where after you will have to take out everything from the distributor there you will find the seal in the bottom... this video will show you just how to do it your self
