water pump changing
will i have to do the whole process of changing my timing belt to get it off or is there a way i can get it off easily i know i'm going to have to take the timing belt off of it to get it off but i mean, can i just get it off without having to take the craft shaft pulley off and etc.
well no i don't take short cuts i like my car to work, i mean i just want to know if i'm going to have to go through to whole process of changing my timing belt just to change the water pump.
To remove the water pump, you have to remove the lower cover. To remove the lower cover, you have to remove the crank pulley. To remove the crank pulley, you have to remove the crank pulley bolt.
OP,does that look the same as the procedure for changing the timing belt?
If you don't like to take shortcuts, and you don't want to believe what anyone is telling you in this thread, go get the FSM for your car like grumble said in the second post and follow it's instructions. It'll tell you the exact same thing we are.
JR CIVIC
Jun 30, 2011 10:54 AM
Jaydeep
Honda Civic (2001 - 2005)
May 24, 2011 04:07 PM
NFrank89
Oct 19, 2010 06:59 AM
therivler1
Jan 11, 2008 08:07 PM
zracer240
Aug 1, 2005 10:07 AM
