91 Accord Head Gasket Oil leak
Though i've already posted this on other forums, I want to post here to.
There is what appears to be a head gasket leak.
This motor was just rebuilt and has only 2000 miles on it. Its not a big leak, only like 1/10 a quart every 500 miles, but it is a concern.
I have pics. This is of the left side on the back:
Zoomed out pic,
It drips down to here where the oil pan is. At first I thought it was leaking but on second look it appears not. I just had the pan and the gasket replaced. It is dripping from above:
Because of oil on this area, I thought it was the cam seal or the VC gasket, but when I looked at the cam seal it was dry, and I also re-applied the VC gasket which was already new so shouldn't have leaked; those two are not leaking. When I cleaned it off, each time oil came back:
That was when I looked underneath and noticed oil seeping from where the head meets the block.
There is no coolant in the oil and not oil in the coolant. I put the HG on backwards the first time and later fixed it, but I torqued it down backwards. I never ran the car with it on backwards (thankfully). I may have deformed the HG though by torquing it down backwards. Think this caused my problem? I tried to tighten it back up again but that did not fix the issue so I do not know what to do next other than replace the head gasket. It is not an OEM one so maybe that is why its doing this. I used copper spray if that matters.
Should I fix it now or would it be safe to wait a while, I don't have many funds to fix it now.
Zoomed out pic,
They seem nice, it was actually on sale for 3.99 from advance with 5 qt's of Valvoline high mileage. It was one of those "hot deals". Its alot better than the Fram filters, heard those were crap.
On to the subject though my friend.
redacura
Feb 17, 2019 05:34 PM
