CRV/ELEMENT TRANSMISSION CASE
HELLO TRYING TO FIGURE OUT IF THE ELEMENT MANUAL AWD TRANSMISSION CASE OR MOUNT IS SIMILAR TO THE TSX OR RSX TRANNY? TRYING TO MOUNT ONE IN A EG 95 CIVIC HATCH?
THANKS IN ADVANCE.
THANKS IN ADVANCE.
stop bumping this. There's literally ~25 people that even come to this forum and none of them either know the answer or give a **** to answer it because you used all caps in your first post then were a ******* when someone called you out.
ALL CAPS IS HARD TO READ PEOPLE READ THE SHAPES OF WORDS NOT EACH INDIVIDUAL LETTER.
Your question doesn't even make sense.
"IF THE ELEMENT MANUAL AWD TRANSMISSION CASE OR MOUNT IS SIMILAR TO THE TSX OR RSX TRANNY?"
what the heck are you even talking about? Stop, think about what you are asking, then ask. You just typed some jumbled all caps words and hoped the internet would solve your problems.
And damn the caps mean nothing it was on I was in a rush didn't turn them off, sorry if it offended anybody. Getting butt hurt over caps really and you call yourself a man?
all caps is gay,and i dont really understand the question, but ill answer your question as "no". Nothing in the 97-01 crv (which is what im assuming youre asking about, because you said something about putting "it", whatever "it" is, in a EG) matches up to a tsx or a rsx.
Dude just shut up. Honestly.
You wrote a poorly worded question in all caps with NO information on what you're trying to do or what you're using. Coming from the one who said "Funny how the Internet gives people ***** since they are hiding behind a computer and thousands of miles" you sure have that "internet warrior" mindset.
Come back with a correctly worded and information rich question and we MAY actually be able to help you.
are you trying to mount an element motor/tranny into an EG? is that your question? you will probably gonna need special mounts and maybe a little modification for that.....never heard anyone done it before...but hey...if you figure it out let us know....what exactly are you trying to do
you all need to relax
Cant use a s2000 diff unless your planning on running all wheel drive all the time with no coupling to transfer power the difference in ratios would burn out the viscous coupling most people use for this swap. As far as i know the 2000-2004 crv and element transmissions bolt right up and you use rsx shift pieces. Doing an awd swap isn't easy though. your gonna need to move the subframe in the rear and modify trailing arms to work with a rear diff and axels. Unless you have alot of knowledge and fabrication skills or money i wouldn't even bother. That's coming from someone who's in the middle of a similar swap into a crx ^^. the following link should help you. You might want to direct any more questions to k20a.org who deals in more k related subjects.
http://www.k20a.org/forum/showthread.php?t=97201
Joe007
17
May 16, 2007 06:30 AM
Spoolin84Gsl-se
Nov 1, 2004 07:36 AM
