d16y7/y8 mini me swap problem need helpp!!
Old Oct 29, 2012 | 08:58 AM
uindaway's Avatar
Post d16y7/y8 mini me swap problem need helpp!!
ok so i've just done a mini me swap. (y7 block/y8 head)
now im having problems. i don't know what i've done wrong.
i used a y8 intake manifold, it will start up and idle fine, but when i give it gas it just bogs down and wants to shut off. (not drivable)
now, i used the y7 intake manifold, and it will rev up and everything but it has a idle issue (every start revs up to 3k rpm and drops and keep going up and down). (driveable)
TIMING IS ON POINT. I'VE CHECKED TIMING NUMEROUS TIMES.
i am using the p2p ecu. (civic ex ecu)
i haven't wired vtec yet, could that be the issue why it wont rev up with the y8 intake manifold?
NOW BEFORE YOU TELL ME TO GOOGLE IT OR SEARCH IT, I DID. AND IT SEEMS LIKE IM THE ONLY PERSON THAT HAS THIS ISSUE.
if anybody has had this issue before and knows how to fix it, please let me know. it will be really appreciated.
and PLEASE NO NEGATIVE COMMENTS. Stay positive my friends lol
Old Oct 29, 2012 | 10:03 AM
sde780's Avatar
Default Re: d16y7/y8 mini me swap problem need helpp!!
Sounds like a TPS issue with the Y8 manifold, and IACV/vacuum leak with the y7 manifold
Old Oct 29, 2012 | 11:15 AM
uindaway's Avatar
i've checked all sensors and they are good. is there anything else that could be the reason?
Old Oct 29, 2012 | 11:30 AM
sde780's Avatar
Did you test the TPS with a multimeter? Or did you just glance at the TPS and assume it's fine? Can you take a picture of where your TPS is?
Old Oct 29, 2012 | 02:20 PM
uindaway's Avatar
no i cant take a picture of it.
but i let the car run and disconnected the tps plug and the engine cut off.
i heard thats the way you can test to see if a sensor is bad or not.
but its located on top of the throttle body, and no i didn't test it with a multimeter
Old Oct 29, 2012 | 03:42 PM
HondaPartsHero's Avatar
Technical Hero
did you convert to a 2 wire IACV? Is your check engine light on and if it is post your codes? What is your year/make/model? What year engine did you use?
Old Oct 29, 2012 | 03:48 PM
canadaek's Avatar
the map sensor is on top of the throttle body the tps is on the back side.
Old Oct 29, 2012 | 04:20 PM
howangseg's Avatar
boom
Old Nov 1, 2012 | 02:48 AM
Demented98's Avatar
i had a similar issue ... revving ... turned out to be the intake mani gasket was leaking ... "vacumn leak"
potentially something to check for ?
Old Nov 1, 2012 | 08:08 AM
med-care-guy's Avatar
Hey guys im kinda really a noob wen it comes to hondas sience i just bought my 1st ever civic nd heard about the mini mi swap witch sounds like sometin id really like to do so ma question is what kinda block my car has its a 93 honda civic lx 1.5 l4 16v i dnt knw if i can even do a mini mi swap cuz i dnt knw what all the Ds nd the Bs 15 &16 nd Ys nd blah blah mean so can i do a mini mi on that car or not if so what head should i get hg tb ne sensors nd ecu i need in my parts list to do a good job sience the cars goin to be for the wife we cnt have it have ne probs ne responce would be great guys
Old Nov 1, 2012 | 08:22 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Learn grammar and sentence structure. Then read all the FAQs up top of this forum. Finally make your own thread about your issue and do not thread jack someone else.
Old Nov 1, 2012 | 11:04 AM
sry didnt knw this was english class nd how hijack if the op was talking bout mini mi swaps nd like i said im a noob stop trynna just post to be a ***** these forums are about learning and other gear heads to help not to once again be a ***** thanks for the responce tho
Old Nov 1, 2012 | 11:23 AM
doctorake's Avatar
Community Builder
No one can understand what you are saying, it took me 10 minutes to piece together that crap.
Old Nov 1, 2012 | 01:05 PM
Technical Hero
Please start your own thread and not to be harsh but use spell check.
Kanaloa5305
Mar 24, 2012 07:45 PM
boostedion
18
Apr 12, 2011 05:16 PM
92civic_eg
Aug 18, 2004 06:24 PM
Ricey McRicerton
May 19, 2003 08:04 AM
