h22a turbo
Old Oct 28, 2012 | 07:25 PM
michael78's Avatar
Default h22a turbo
Ok I'm new at this one.I have a built h22a vtec that's built pretty good.it has je turbo pistons eagle rods,arp studs.I know its running 9:01 compression.my question is i don't have money to turbo it right now and,I have to use the engine now because my other engine went down.this engine is built out the *** too much to list.what kind of HP does it have running it without the turbo.would I be better off putting factory pistons back in to get the factory HP back,or will it be ok to drive it the way it is now.will it hurt the engine if I raise hell in it once in a while.can I raise the compression to get the HP back or did I loose a lot of HP by buying it with low compression turbo pistons.sorry so many questions.I'm new at this so please don't hate on me or say negative things I'm here for help.thanks u can email me if u don't mind.
Old Nov 2, 2012 | 06:32 AM
sde780's Avatar
Default Re: h22a turbo
As long as you're tuned for your current motor you'll be fine. In fact a basemap will probably be just fine for putting around town until you can install the turbo
Old Nov 5, 2012 | 04:00 AM
michael78's Avatar
Hey I app it.just one more question.my 94 is obd 1 the only vtec wiring harness I have is obd 2 and the vtec computer is obd 1 but I have and obd1 to obd 2 jumper.would it be better to just go ahead and make my car obd2 or find an obd1 vtec wiring harness.my car never was vtec its factory wiring harness is obd1 with a f22b2 in it.and thanks for the info on my last post I app it
Red-Line
Nov 11, 2011 11:14 AM
96lewd
Nov 18, 2005 07:07 AM
type-t
Aug 25, 2004 09:36 PM
MeLuvHoNda
Dec 30, 2003 09:10 PM
brian2903
Oct 18, 2003 08:07 PM
