Poor Man's Type R Motor
I have for sale a poor mans type R setup. This motor was built and swapped into my integra back in April 2012. It was daily driven up until 10/16/12. The Motor is pulled from my car and it currently has just over 7000 miles on it. It has no issues and runs strong. The only reason I am selling it is because I have decided to take on a K20 build for my integra.
This is a FULL swap and will come with EVERYTHING needed to swap into your car plus a bunch of extras. Just swap it in and go!
Motor:
Stock B18c1 Bottom End
ARP head studs
Gates racing water pump
Gates racing blue timing belt
B16a head
GSR cams
Skunk2 adjustable cam gears
ITR intake manifold (polished)
Golden Eagle thermal intake manifold gasket
ITR throttle body
Zerg thermal throttle body gasket
AEM fuel rail
Blox fuel pressure regulator
Stock 240cc injectors
RMF Replica 4-1 header
NGK plug wires and spark plugs
Drivetrain:
GSR transmission (3rd grinds at times)
F1 racing chromoly 12lb flywheel
F1 racing stage 2 clutch
GSR axles
Motor will also come with:
Extra set of Hasport 200hp Axles which need new boots
Motor wire Harness
Stock Integra motor mounts
Torque mounts with Energy suspension poly inserts
Shift linkage with shifter
JDM obd1 Integra SIR-G (GSR) ECU
Obd1-obd2 conversion harness
Rywire vtec conversion harness
Integra radiator with Fans and hoses
Powder coated yellow valve cover
Carbon fiber spark plug cover
EVERTHING listed above is included in this swap. I will NOT part out. Motor is awaiting it's new home under the hood of your car. Buyer can pick up or I can deliver depending on location.
Price is $2500. . .I am willing to negotiate so throw me your best offer. Worst I can say is no. Cash only. . .no trades!
I am located in Oklahoma city, Oklahoma so the closer you are to my location, the better. Hit me up for details.
here is a video of the motor running the day before i pulled it.
http://youtu.be/ysm6kjmDXLI
Motor:
ARP head studs
B16a head
GSR cams
ITR throttle body
AEM fuel rail
Drivetrain:
GSR axles
Motor wire Harness
