My ep3 CTR
Hi all again friends!
this is my civic type-r ep3:
TRANNY
-quaife torsen lsd
-jdm gears 4-5-6
SETTING
-j's racing ENGINE TORQUE DAMPER WITH STRUT TOWER BAR
-j's racing SIDE INNER BRACE
-j's racing ff roll centre
-j's racing steering tie rod
-J’s racing STRUT TOWER BAR (REAR UPPER)
-J’s racing LOWER ARM BAR (REAR)
-anti-roll from jdm civic type-r ep3
-oem shock absorber with tein s.tech springs
-inserts engine energy-super pro
-energy sway bar bushings
BRAKE
-spoon 4 pot calipers
-j's racing brake discs fcr
-goodridge brake lines front-rear
-ferodo ds 2500 pads brake
EXTERIORS
-R1R TOYO tyres 215/45/17
-OZ.Alleggerita matt black
-carbon hood j's racing
INTERIORS
-greddy guages oil pressure,oil temperature,water temperature
ENGINE
-toda headgasket 0.3mm,
-toda a2 cams
-toda valvespings
-oem retainers
-Hybrid chain tensioner
-air duct
-custom cai 3.5''(90mm)
-rbc ported
-hondata gasket
-j's racing t/b
-dcrh 4-2-1
-exhaust 70mm custom
-j's racing thermostat
-j's racing thermo switch
-j's racing Magnetic bolts gearbox-oil pan
-Samco water hoses
-buddy club racing spec condenser
Without much pushing, here an acceleration 0-200km/h
TRANNY
-quaife torsen lsd
-jdm gears 4-5-6
SETTING
BRAKE
EXTERIORS
INTERIORS
ENGINE
-toda a2 cams
-toda valvespings
-oem retainers
-air duct
-rbc ported
-hondata gasket
-j's racing t/b
-dcrh 4-2-1
-Samco water hoses
I bought:
-F22 crank
-CP 87mm 12.5 c/r
-inlinePro rods
-4.389 final drive (rsx 2002-2004)
-walbro 255
-golden eagle head gasket 87mm
-new oem valves
-new oem retainers
-new oem chain
-fx 400 cm
With the existing:
-hybrid racing chain tensioner
-toda a2 cams -valvesprings
-j's racing t/b
-hondata gasket
-ported rbc
-custom cai 90mm
-dcrh
-76mm exhaust decat with one finally mufler
-rdx injectors
2.157cc project!
I hope to make ~300 horsepower
-F22 crank
-CP 87mm 12.5 c/r
-inlinePro rods
-walbro 255
-new oem valves
-new oem retainers
-new oem chain
-fx 400 cm
With the existing:
-j's racing t/b
-hondata gasket
-ported rbc
-custom cai 90mm
-dcrh
-rdx injectors
2.157cc project!
315 hp engine
1200kg w.o.me
89X90.7
Darton sleeves
cp 12.5 cr 89mm
f22c1 crank
inline pro rods
4-1 exhaust header custom
90mm cai custom
76mm exhaust
prayoonto stage 3 cams
intake 35.5mm valves supertech 3 angle valve job
ex valves stock
ported rbc
1200kg w.o.me
89X90.7
Darton sleeves
cp 12.5 cr 89mm
f22c1 crank
inline pro rods
90mm cai custom
76mm exhaust
ex valves stock
ported rbc
N1ConceptsC
17
Aug 2, 2010 09:52 AM
