obdIIa gsr swap into obdIIb LS and speedometer is too fast
Old Oct 28, 2012 | 02:35 AM
tekstyle's Avatar
Default obdIIa gsr swap into obdIIb LS and speedometer is too fast
chief complaint:
odometer in my car now is registering too fast. a 65 mile trip shows up as 80 miles on the odometer. even with 205/55/15R tires (using over sized tires should register less than 65 miles on the same trip, not more)
History of present problem:
a few years ago, i swapped a obd-2a ECU and b18c1 from a 99 gsr into a obd-2b equipped 2000 integra L. obviously, i am using the gsr tranny, b18c1, and obd-2a ECU in the newer body. I am also using the 99 gsr gauge cluster but I swapped the speedometer from the LS into it so I can maintain the same odometer reading.
I do not have the gsr cluster anymore and it doesnt work anyways because the ABS light stays on, and the coolant and fuel gauges are all off when i use it.
assessment:
tho the LS speedometer is close to what the gsr speedometer would register, the speed difference is not consistent throughout the speed range so i can't just pop the needle off and reposition it to match my tachometer.
do i need to replace the speed sensor at the tranny with one for an 00 LS? can I do something to the wiring behind the cluster like add a resistor or something?
thanks everyone. this is driving me nuts because i have to use the GPS to figure out my speed and it's getting really annoying having to depend on it constantly.
Old Oct 28, 2012 | 07:51 AM
el crapitan's Avatar
Default Re: obdIIa gsr swap into obdIIb LS and speedometer is too fast
so which speed sensor are you using?
Old Oct 28, 2012 | 08:00 AM
tekstyle's Avatar
Directly swapped gsr tranny with sensor over. So gsr speed sensor
Old Oct 28, 2012 | 08:03 AM
hmmm. that is strange. and which cluster is in there now? sorry. the post was a bit confusing
Old Oct 28, 2012 | 09:19 AM
tekstyle's Avatar
Gsr cluster but i swapped the ls speedometer back in.
Old Oct 28, 2012 | 10:53 AM
ok well that may be the problem. maybe the calibration on the ls speedo differs from the gsr gear. maybe see if anyone who's swapped in a gsr trans w/ vss has and still retained the ls cluster has had the same issue.
either that or there is a problem with vss/gear. however, that usually results in an irradic reading
Old Oct 28, 2012 | 12:50 PM
tekstyle's Avatar
the thing that threw me off was that the VSS on the LS is the same as the GSR according to this thread http://forums.g2ic.com/showthread.ph...GSR-LS-cluster
and if the VSS gear is independent of the final drive and gear ratio, the gsr gear ratio shouldnt affect the readings on the LS speedometer.
Old Oct 29, 2012 | 05:58 AM
50psiboostinteg's Avatar
Thats interesting, mines too seems to moving too fast, I know 2 blocks cant be a mile.
Old Oct 29, 2012 | 06:46 PM
tekstyle's Avatar
wow, that's really off. do you have the same setup as me?
gsr motor/tranny/VSS/ecu
ls speedometer
xander1100
May 22, 2009 12:59 PM
crawlin
Jan 25, 2008 06:09 PM
ac_attak
May 30, 2006 07:32 AM
dc9turbo
Mar 5, 2005 01:37 PM
Hairy Gorilla
Jul 16, 2002 06:14 PM
