All Motor D16z6 156whp
Old Oct 27, 2012 | 08:10 PM
Tong.Y's Avatar
Default All Motor D16z6 156whp
10/27/12 Dyno Day
The car was tuned 2 months ago by DB Perormance, It made 153whp 116wtq on their dynamic dyno. This was my daily, now that I've put a good 5000+ miles on it i wanted to try it on MAPerformance's dynojet and see if it made any difference.
3 pulls maxed out at 156whp 121wtq.. not much of a difference but all i really think what made the difference was the change in temperature. it was around 40-50 degrees out.
I didn't get a print out of the graph but i should be getting a digital file of it sent to my email from a friend.
Bottom:
Stock D16z6 block 75mm bore
All stock internal OEM parts balanced (Crank, rods, flywheel, pulley, piston)
P29 pistons used
Kings main and rod bearing
Reused stock oil pump and water pump with unknown mileage
Head:
Stock D16z6 Head
Ported polished myself
3 angle valve job
Stock valves
Crower Springs and Retainers
Crower stage 2 camshaft
AEM camgear
Cold NGK plugs
Edelbrock performer X manifold
B16 60mm Throttle body
Stock Injectors & fuel rail
3in blox velocity stack with 3in intake piping
Misc
ARP head stud
DC 4-1 header
Greddy Spectrum Elite 2.25in exhaust
Crome
92 octane
D16z6 vs B18c1 (skunk2 IM, stock header, 60mm exhaust + tuned)
Old Oct 27, 2012 | 09:01 PM
turbo1.5's Avatar
Default Re: All Motor D16z6 156whp
Nice!
Old Oct 27, 2012 | 09:59 PM
Tong.Y's Avatar
Old Oct 28, 2012 | 12:00 AM
riceburner700's Avatar
got any pictures of the port work, did you mill the head any good amount?
Old Oct 28, 2012 | 12:23 AM
oversteer_ms's Avatar
Who did you have balance the bottom end? Price?
Thanks in advance.
Austin
Oversteer Motorsports
Old Oct 28, 2012 | 07:22 AM
nealnanoHX's Avatar
Pretty low compression for that cam. If you swapped to higher compression pistons you will see a good gains, taking full advantage of the cam. It is kind of hard to believe that motor made 153whp with a stock Z6 bottom end, DIY head work and a cam.
Old Oct 28, 2012 | 08:03 AM
ennah's Avatar
^^ He stated he used the P29 pistons. He isnt exactly a stock block. Anyways thats what i got from read the OP
Old Oct 28, 2012 | 10:01 AM
Tong.Y's Avatar
sorry i didn't get any pictures of the port work. this was my first ever port work i've ever didnt and first motor i've ever built! "do it right the first time" i suppose LOL
Old Oct 28, 2012 | 10:03 AM
Tong.Y's Avatar
Thanks in advance.
Austin
yes I got the whole internal assembly balanced cleaned and crank micro polished for 500+
Old Oct 28, 2012 | 10:04 AM
Tong.Y's Avatar
p29 12:1 pistons were used.
Old Oct 28, 2012 | 10:11 AM
Superfluidity's Avatar
Well, I would say the engine is above 12:1. Not bad at all but it still can put more... 15Whp more are easy to get.
Old Oct 28, 2012 | 10:55 AM
Tong.Y's Avatar
it should make 160+ on e85..
Old Oct 28, 2012 | 11:27 AM
Highly probable with a very nice head it can make 175Whp.
Old Oct 28, 2012 | 06:55 PM
Tong.Y's Avatar
graphs updated
Old Oct 28, 2012 | 07:06 PM
Charlie Moua's Avatar
Hahah, thanks for coming out.
Gotta love the Dave for putting on the Gundan Style song for you being the only honda on a VW/Audi dyno day. lol
I've never seen anyone with that header...
I'd love to test that header back to back with my EdelBrock header... maybe next spring
Old Oct 28, 2012 | 07:18 PM
Tong.Y's Avatar
Originally Posted by Charlie Moua
Looking great pal.
I've honestly never seen anyone with that header...
sure thing! though i just found out that anything carb is "small" but i got it just for the sake of it being 4-1 hahaha.
Old Oct 28, 2012 | 08:50 PM
m_shake's Avatar
Nice #s dude
Old Oct 28, 2012 | 09:44 PM
661rex89si's Avatar
great numbers even with the small collector of that dc header. You can probably see a bit more power from a smsp or custom header. i think 2.5 inch intake pipe would be better i think the 3inch is overkill. bigger is not always better with the d-series. Just my opinion though not trying to nit pick on your set-up just experience. either way im impressed its a solid set-up with potential for more.
Old Oct 28, 2012 | 09:48 PM
661rex89si's Avatar
well more close to 2inch collector but around 1.82". you can always have the collector modded to a true merge collector,reverse cone reduced to 2.25 to get that anti reversion. should help a lot actually its what i wanted to do with my old 4-1 dc header.
Old Oct 28, 2012 | 10:02 PM
661rex89si's Avatar
i would like to see that as well even though i would put my money on the Edelbrock header since it has stepped primaries that taper down once they get to that long collector.
Old Oct 29, 2012 | 05:09 AM
I also have a bisi replica header to try out.... the collector is so so, but we'll see if it makes power. lol
Old Oct 29, 2012 | 05:27 AM
I agree with this about the collector. What could end up happening with a bigger collector diameter can be a little bit loss of overall power and a significant reduction in torque, at least for my experience. The DC 4-1 is a very good header for this set-up. Sure This car can run high 13's with slicks and some weight reduction :D
Old Oct 29, 2012 | 05:29 AM
The power ban in the graph looks awesome.
Old Oct 29, 2012 | 11:54 AM
Tong.Y's Avatar
Originally Posted by m_shake
Nice #s dude
thanks for the input guys. I bet it'll run low 14's with slicks. i've seen stock gsr's swaps with slicks run 14 consistently.
Old Oct 29, 2012 | 07:15 PM
I bet it will run low 13's with 22x8, just do a good burnout and make the car more lightweight for the track day. Remove seats and every part from interiors that you believe can do improvements in the weight. Good luck!
