built b16 idle issue
Old Oct 27, 2012 | 02:20 PM
dannykhaos's Avatar
Icon2 built b16 idle issue
setup:
b16a
overbore ctr pistons
gsr cams
blox valve springs and retainers
head and block decked .001
stock fuel setup besides inline fuel filter (summit)
edlebrock victor x
stock tb
8lb flywheel
stock p28 (getting phearable.net chip on friday)
Info:
so my issue is I have a bouncing idle during the day and it will stall the car when at a light or between shifts. at night it will usually idle perfectly but sometimes it acts up at night as well.
issue started when i swapped to a victor x im, new (used) altenator, and added a/c (a/c has since been removed since the weather is getting nicer in AZ.
sensors and manifold worked perfect on the previous owners car (buddy of mine)
only cel I have is o2 sensor and that only comes on during heavy load
when I unplug the IACV it dies
blows smoke in vtec
engine has like 10,000 miles since full rebuild
stuff i have done:
tb has been cleaned
IACV has been cleaned and swapped
valves have been adjusted
timing is right
idle screw has been adjusted
distributor replaced
no vac leaks
spark plugs have been checked
FITV is deleted
coolant is bled
grounds are all good
any ideas before I start throwing more money at it?
my thoughts are replace:
tb/tps
fuel pump
injectors
o2 sensor
get ECU chipped until I can afford a tune
Old Oct 27, 2012 | 02:44 PM
grumblemarc's Avatar
The Grumpiest
Default Re: built b16 idle issue
Wrong ECU. Why are you running an ECU meant for a SOHC on a DOHC engine? And a modified engine at that?
Old Oct 27, 2012 | 03:13 PM
dannykhaos's Avatar
this being true it still ran fine before the manifold and altenator
answer: money... it will be chipped soon
Old Oct 27, 2012 | 07:13 PM
hybridmiklo's Avatar
check for vacuum leaks at the manifold and the tbody. spray brake cleaner and see if the motor reacts. check the chargin system. make sure it is charging.
and, of course the motor wont run right if you are running of stock ecu. Plus, o2 sensor has alot to do with driveability. Fix that problem first after checking for vacuum leaks
Old Oct 28, 2012 | 07:28 AM
dannykhaos's Avatar
no vac leaks.
ill check charging system tonight.
o2 will be deleted on Friday when I send my ECU to phearable.net for chipping.
Old Oct 28, 2012 | 09:34 PM
Checkmarks's Avatar
If your IACV is good then you have a vacuum leak. Look harder for the vacuum leak, it is there.
Old Oct 29, 2012 | 07:43 AM
dannykhaos's Avatar
would the vacuum leak only be there during the day?
its weird it will run purrrrfect the second the sun goes down.
Old Nov 18, 2012 | 07:17 AM
dannykhaos's Avatar
so I now have a Pherable.net chipped ECU and im still having the same issue with my idle...
now that it is really cold out the car barely wants to run at all
any tips?
Old Nov 18, 2012 | 12:59 PM
Is this thing tuned? If this thing is not tuned than obviously thats a problem. especially if you delete the o2 sensor. Now the ecu doesnt even know the a/f of the motor. Its running of a guessed map.
And if you are wondering, yes, replacing the intake manifold with change the a/f ratio just like putting a header on.
Old Mar 3, 2013 | 01:41 PM
dannykhaos's Avatar
pulled the head and found that 3 pistons were cracked below the top ring and one had a huge chip missing from the top.
I'm blaming bad tune
LESSON LEARNED
jameson_g
Dec 13, 2012 08:11 PM
dannykhaos
Oct 14, 2012 09:35 AM
DB2-R81
Engine Management and Tuning
17
Dec 10, 2010 11:16 AM
escourt23
11
Dec 2, 2005 08:14 AM
B16EKrevdupto10krpm
Feb 23, 2005 12:39 AM
