00 civic si - starts up but as soon as i press the gas, it cuts off
Old Oct 27, 2012 | 11:46 AM
richy_civicsi's Avatar
Post 00 civic si - starts up but as soon as i press the gas, it cuts off
hey i have a 200 honda civic si b16vtec on 50 trim garret turbo runnin on 7lbs and last week i was drivin and all of a sudden it cut off and it cranked right back on but as soon as i press gas it cuts right back off?? can anyone tell me if dey have had this problem before i tried changin fuel filter and nothin i need some help asap
Last edited by Former User; Oct 27, 2012 at 12:18 PM. Reason: more detailed problem description added
Old Oct 27, 2012 | 12:08 PM
98civdx's Avatar
Master Detailer
Default Re: 2000 civic si
Have you checked to see if it's getting fuel? Spark?
Old Oct 27, 2012 | 12:16 PM
Former User's Avatar
Default Re: 00 civic si - starts up but as soon as i press the gas, it cuts off
Check the mechanical timing.
Old Oct 27, 2012 | 05:48 PM
Cesar_gsr's Avatar
Check the dizzy happened to me on wendsday I got stranded the car would start but as soon as I have it gas it would die out. I ended up changing the fuel filter and pump thinking it was it.
Old Oct 28, 2012 | 04:18 PM
kd82289's Avatar
check tps sensor had the same problem
Old Oct 29, 2012 | 04:01 AM
Thanx every1 but can everyone gibe me feedbak on
How to check those things yall are tellin me
To chek om fairly new to honda game
Old Oct 29, 2012 | 05:40 AM
Click the spark link in my signature.
Listen for whether the fuel pump primes for 2 seconds when the key is turned from off to ON(II).
Turn crank pulley counterclockwise until cam pulleys are at TDC1. Then check whether crank pulley is also at TDC1.
Old Oct 29, 2012 | 08:22 AM
i tried turnin it on yest and nothin now it wont crank period
getzy3
19
Apr 19, 2023 03:23 PM
ReezyJ
May 1, 2010 02:20 AM
MI4$DC5
79
Apr 13, 2010 11:13 AM
mikeyandem
Aug 26, 2005 01:07 PM
xfrankx
Jan 27, 2005 09:12 AM
