90 accord smog fail
Old Oct 27, 2012 | 10:46 AM
closp's Avatar
Icon6 90 accord smog fail
Help please ! I have a 91 accord, I have replaced the o2 sensor' new spark plugs,cap, rotor,wires, and can't pass the smog here are my readings
Rpm 1857[ %co2 -14.0] O2%-0.4 [hc max 83 meas. 63] CO % max.75 meas. 1.37 ]No max 559 meas. 256
Rpm1932[ %CO2 14.1]O2%-0.3] BC max65 meas. 38 [ CO% max.63 meas. 1.35 ] no 184
Old Oct 27, 2012 | 08:17 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: 90 accord smog fail
Change the thermostat. Change the oil.
Old Oct 28, 2012 | 10:02 AM
closp's Avatar
I just noticed that my upper radiator hose was sucked in, I replaced the hose and the radiator cap. I will replace the thermostat today and repost if it passes. thank you
Old Oct 28, 2012 | 02:42 PM
sightsandsounds's Avatar
Check the catalitic converter ?
Old Oct 29, 2012 | 05:43 PM
TCDUS3's Avatar
i'm having the same problem and i also live in california here are my readings
Rpm 1782[ %co2 -9.6] O2%-5.1 [hc max 83 meas. 3218] CO % max.75 meas. 3.10 ]No max 559 meas.187
Rpm 2471[ %CO2 13.9]O2%-0.4] hC max65 meas. 11 [ CO% max.63 meas. 1.21 ] no max 516 meas 265
Old Oct 29, 2012 | 10:42 PM
closp's Avatar
the smog tech told me that its not close enough where the cat would fix it.
Old Oct 29, 2012 | 10:46 PM
closp's Avatar
have you done anything to try and better the number ? oil change spark plugs etc.
Old Oct 30, 2012 | 08:52 AM
TCDUS3's Avatar
I've done all of that and then some. I talked to my dad last night and he talked to a friend that works at a Honda dealership and he told him exactly what ths problem was got get the exact name of the piece and I'll tell you what it might be since it sounds like were having the same problem
Old Nov 1, 2012 | 07:06 PM
closp's Avatar
please do let me know if you had any luck
Old Nov 4, 2012 | 06:54 AM
TCDUS3's Avatar
Car passed Smog with flying Colors. There are some plugs that sit by the and on the exhaust manifold that were plugged took them out went to the Honda dealership they cost $2.95 put them in and it's fine now
Old Nov 4, 2012 | 07:47 AM
v4lu3s's Avatar
RTFM
i would like more info about these plugs on the exhaust manifold. to me it sounds more like plugged egr ports.
swamp_ass
Jan 6, 2019 02:48 PM
OldReliable
Dec 1, 2015 02:04 PM
RedRoach68
Classic Hondas
Feb 21, 2015 03:47 PM
Ardfarkle
May 27, 2004 03:55 PM
