No more Idle with 70mm SK TB
Old Oct 27, 2012 | 09:46 AM
Steeve_Civic's Avatar
Default No more Idle with 70mm SK TB
Since I've changed my TB by a 70mm skunk2, I have no idle.
I must do it with my Accelerator cable?
Do you have an idea please?
I use S300
I've tried to change the IACV or disconnect it and no difference
Thank you.
Old Oct 27, 2012 | 09:49 AM
Former User's Avatar
Default Re: No more Idle with 70mm SK TB
In your first post, please provide all pertinent information about your car and engine.
Old Oct 28, 2012 | 12:32 AM
Here is my car
B18C1 with AEBS Sleeves 84mm
- 84mm CP pistons 9:1
- Eagle rods
- Turbo: T6766 AR.86
- Tial 44mm W/G
- Precision Turbo Intercooler 18x12
- B16 Head
- 84mm GE Headgasket
- Skunk 2 Pro 1's cams
- Supertech valves and springs
- Ik24 Spark Plugs
- AFI Turbo Front Facing Exhaust Manifold
- AEM Fuel Rail
- SKunk 2 70mm
- 750cc RC Injectors
- HONDATA S300
- ATI damper
- Hasport Engine mount
https://honda-tech.com/forums/drag-racing-36/my-eg-drag-car-3075732/
Do you know where is my idle problem please?
Old Oct 28, 2012 | 03:39 AM
grumblemarc's Avatar
The Grumpiest
Retune it. Anytime you modify anything that deals with air/fuel you will need to retune.
Old Oct 28, 2012 | 04:46 AM
My AFR is correct when I adjust my idle with the cable but IACV don't work
Old Oct 28, 2012 | 05:24 AM
The Grumpiest
I didn't ask about your AFRs.
Do you know how to work your S300?
Did you change out the throttlebody BEFORE or AFTER you had it tuned?
Is it, in fact, actually tuned?
And maybe you might want to fix all your known deficiencies first? Like that IACV thing?
Old Oct 28, 2012 | 10:45 AM
Yes on S300 I configured the new TB as Fully close and fully Open.
Do I need to do something more?
Old Oct 28, 2012 | 03:32 PM
1998GsRIntegra's Avatar
Idle adjustment screw on the throttle body may need adjusting.
Old Oct 28, 2012 | 03:42 PM
allmotorgsrekk's Avatar
Maybe you just mixed up the tps and map sensor?
Old Oct 29, 2012 | 09:30 AM
Ok I'll try tomorrow, thank you
Old Oct 29, 2012 | 10:23 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
If you moved the Tps sensor you may need calibrate it
Old Oct 29, 2012 | 11:52 AM
On my laptop:
Scale TPS
Minimum: -3,51
Maximum: 88,26
On IDLE table,
Minimum: 1000 rpm
What is IAC Duty please? the arrow is on decrease
Thank you
Old Oct 30, 2012 | 11:02 AM
Someone please to help me?
jameson_g
Dec 13, 2012 08:11 PM
jdm.ejone
Jun 15, 2008 04:50 PM
crizx89
May 6, 2008 03:53 AM
w0ng_sta
Aug 31, 2006 02:25 PM
eg:R
Mar 26, 2006 10:23 AM
