Diamond cut wheels
Whats up everyone! New guy here, so im wanting to put a set of the factory acura 19" diamond cut wheels on our 2007 accord v6. How can i make that happen? Axle swap/hub swap? Anyone done this? Thanks in advance for any input.
Well, the TL is 5x120, and your car is 5x114.3. You're looking at either changing the bolt pattern on the car (there's a few ways to go about this, but they'll all be rather expensive) or buying adapters (which will probably need to be 25mm to 30mm thick to clear your stock lug studs).
You really won't be able to noticeable the adapters, when the wheels are on. If you purchase bolt-on adapters from a reputable company, they're completely safe.
The adapters would be the easiest route, but due to their thickness... you're going to have less clearance to the outer body panels, then if you went the harder route.
Good adapter company: http://www.motorsport-tech.com/
