eg hatch/b16/gsr trans - would any b-series axles work?
94-01 for the drivers side, because of the halfshaft. 90-01 for passenger side.
90-93 use a halfshaft with a female end instead of male, however if you have one of these, you can use the corresponding axle.
Automatics, the bracket on the halfshaft won't line up correctly with the holes on the transmission. The axle shafts should be the same, but I've never checked that personally.
tallguy21
Mar 6, 2012 06:30 PM
