front signal/corner lights power source
Old Oct 26, 2012 | 06:48 AM
CrisFerio's Avatar
Default front signal/corner lights power source
I was having issues with my passenger front corner lights. Has no constant power wire it was cut -_- now there no wire for it so im going to domit from scarcth. I'm trying to figure if its power source is from the inturment panel harness plug from the fusebox or from one the main harness plugs. I just wanna make sure Google only helps so much. Thanks in advance
Old Oct 26, 2012 | 11:14 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: front signal/corner lights power source
How much of the wire is cut? Trace it back and extend the length you need.
Old Oct 26, 2012 | 03:20 PM
CrisFerio's Avatar
The harness is tuck under the fender. I removed it and cant find the matching wire to the corner light plug. I'll probably have to get under the dash thru the passenger side.
Old Oct 26, 2012 | 05:58 PM
d15bvtechatch's Avatar
the wire runs to the fuse box in the cab. it has a ground on the inside of the bay. multimeterrrr
Old Oct 27, 2012 | 02:30 PM
CrisFerio's Avatar
Thanks, got it fix
worx
Jan 1, 2010 05:06 PM
eg6madness
Lighting
Sep 30, 2008 12:03 PM
philkehn
Sep 20, 2006 04:08 PM
O RLY
Audio / Security / Video
Nov 3, 2005 07:30 AM
lostsurfer00
Oct 13, 2002 08:19 PM
