CODE 9, STILL!!
Old Oct 26, 2012 | 05:03 AM
eg6_vti93's Avatar
Icon2 CODE 9, STILL!!
ok so i've still got a code 9 ive replaced the distributor, had the timeing belt done and so is all timed up, and i still have it so i stripped the distributor down and replaced the wireing with another distributor to see if that would work but still have code 9 what else can i do???
Old Oct 27, 2012 | 03:58 AM
holmesnmanny's Avatar
Default Re: CODE 9, STILL!!
The problem is probably in the wiring before the distributor or it could even be a bad ecu.
Old Oct 27, 2012 | 09:16 AM
HondaPartsHero's Avatar
Technical Hero
Did this happen after the timing belt or before?
Old Oct 27, 2012 | 11:23 AM
civickiller's Avatar
dist., ecu, wiring, youve already eliminated the dist.
try ecu in someoneelses car
Old Oct 28, 2012 | 06:15 AM
eg6_vti93's Avatar
it happened before the timing belt was done??
Old Oct 28, 2012 | 06:17 AM
eg6_vti93's Avatar
ok so i shall have a look at the wireing before the dist and try a new ecu..
and am i right in saying its a p30 ecu obd1???
Old Oct 28, 2012 | 11:12 PM
oversteer_ms's Avatar
Just to start, what are you working on?
Old Oct 29, 2012 | 12:51 PM
eg6_vti93's Avatar
its a 93 civic eg6 b16a2
Old Oct 29, 2012 | 04:08 PM
continuity test the dist. plug with the ecu plugs
new or new used? brand new is expensive
Old Oct 29, 2012 | 06:50 PM
crzycivic93's Avatar
try ecu.
Old Oct 30, 2012 | 12:31 PM
eg6_vti93's Avatar
i shall try a continuity test sometime this week then with the ecu plugs do you no which wires i need to test??
cornfed
Engine Management and Tuning
Jan 27, 2012 02:49 AM
turbob18si
Dec 3, 2006 04:02 PM
Ch3mik
Jul 19, 2005 04:41 PM
crackercr-x
Aug 4, 2004 05:57 AM
xci_ed6
Feb 28, 2003 03:01 PM
