94 Civic/B16A2 swap - Do I need an integra tranny and rear mount?
so i have a 94 civic lx that had a D16. Pulled the D series and got a B16a2.
converted the B16 to obd1 (dizzy, injectors ext.) have 2000 si shift linkage half and half shafts.
sent my ecu to pheriable chiped p28
using stock mounts but have read i need an integra tranny and rear mount? my D series rear mount wont work?
problems
everything pluged in nicley except i have on loose end that pluged into what looks to be like a fast idle control solinoid but there is not one on my b16??
problems
and what about the bracket going to the front of the transmission kinda like a torque mount the z6 mount that is left hanging in the car has a different bolt pattern then whats on my gsr trans?
Correct me if im wrong but there are 5 mounts correct? driver side passanger tanny and rear t bracket. also a mount that goes from the behind the driver tire into the motor and also on the passanger side which bolts to the tranny??
The FITV does not have a connector, so the loose connector must be something else. Post a picture of the connector and its wires.
It open and sucks fuel vapor into the intake manifold to get burned while at a stop light or in traffic. The entire evap system is for emissions. Some states require it to all be hooked up, some dont.
A lot of people delete the evap canister and purge solenoid, by removing and plugging the ports.
Who knows why the b16 doesnt have it? It originally did at somepoint. Maybe the person who got rid of the swap kept it. Just like it you take your d16 purge solenoid and the next person gets your motor. They will be like why doesnt this d16 have a purge solenoid....
dem0nk1d
Nov 21, 2008 09:44 AM
what is this it is the b16
this is what I am talking about???
this is the the the plug that plugged into into what ever it is
