B18a1 swap in CRX questions
Old Oct 23, 2012 | 07:30 PM
BrandonCRX's Avatar
Default B18a1 swap in CRX questions
I have an 89 CRX Si and a 94 integra ls.... I cant get the title to the integra, so I want to put the b18 in my CRX. The integra has a hydro tranny, so a friend is hooking me up with a b16 cable tranny (freebie). But no axles.. Will it bolt up to my b18 block? If so, will my b18 axles from my integra work with the b16 tranny and in the crx?...... I will ask the rest of the questions I have after someone helps me out with this to make things more simple.. I'm having to piece together my own swap cause I dont have the $$ to fund a full swap all at once.. Any help would be greatly appriciated. Thanks.
Old Oct 23, 2012 | 07:35 PM
BLU CIVIC's Avatar
Track Advocate
Default Re: B18a1 swap in CRX questions
yes the trans and axles will work. you will need to use the intermediate shaft also. i'm using '96 integra axles an intermediate shaft. make sure you get the correct clutch too
Old Oct 23, 2012 | 07:44 PM
BrandonCRX's Avatar
Okay... Which clutch do I need to use? I've read that you need to use the clutch that goes with the same year as the tranny?
Old Oct 24, 2012 | 05:43 AM
BLU CIVIC's Avatar
Track Advocate
look for a 90-93 integra clutch
Old Oct 24, 2012 | 11:49 AM
BrandonCRX's Avatar
Alright... I'm going to stay obd0 for the time being until I can afford the jumper harness and whatever else it takes... Is an obd0 distributor all I have to have? (I found one for 10 bucks at the local junkyard.)
Old Oct 24, 2012 | 02:20 PM
lude72's Avatar
there is two different types of clutches for the 90-93 trans the s1 cable trans (90-91) has a smaller input shaft then the ys1 (92-93) cable trans.. i'm not sure which one a b16 cable trans uses so you better search be for you buy a clutch.....watch out for bad info.....
Old Oct 25, 2012 | 06:51 AM
BLU CIVIC's Avatar
Track Advocate
YS1 trans is from the GSR and the S1/J1/Y1 you'd use a regular LS clutch. well not 100% on the J1
Old Oct 26, 2012 | 06:14 AM
BrandonCRX's Avatar
Well I might not be able to get this b16 trans after all. But I do have a cable trans that has A1 sticker on it that came with a 90 integra I bought. My head has a 92 stamp on it. I've been told that will tell you the year of the engine. So will this A1 trans work with my 92 block? An then what clutch will I need? Sorry for the change up about the thread, but crap happens I guess. Thanks for the help so far.
Catch
Aug 27, 2008 09:00 AM
Kyoh
Jul 25, 2007 11:25 AM
QWKPHKR
Jul 12, 2002 11:15 AM
QWKPHKR
Jul 11, 2002 04:03 PM
