SS brake lines LS/GS/RS vs Type R?
Old Oct 23, 2012 | 04:28 PM
Kennyjai's Avatar
Default SS brake lines LS/GS/RS vs Type R?
Is there any difference between the LS/GS/RS stainless steel brake lines compared with the type R? Are they shorter/longer? And are the fittings the same?
I have upgraded legend 2 piston front calipers,stock rear and just wondering which model I should order for.
Thanks!
Old Oct 23, 2012 | 04:31 PM
Fliptard's Avatar
Default Re: SS brake lines LS/GS/RS vs Type R?
pretty sure ALL honda and acura brake line are the same, I actually have 08 SI ss lines on my EK hatch. little longer but they work just fine.
Old Oct 23, 2012 | 05:38 PM
fcm's Avatar
fcm
Old Fart
G3s are all the same, [same part number] by to looks of it, the G2s are diff., [diff. part number].
The Legend is also diff. diff. years diff. part numbers.
What year are the Legend calipers, what year is the Integra, what brake lines are you using now?
Most of the SS brake lines I find, including the ones on my 94 RS fit all 94-2001 Integra except the Type R, but then there are some that say they fit all Integra, including Type R
Which is strange as the OEM part numbers are the same...
97 RS...
http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
97 Type R...
http://www.acuraautomotiveparts.org/...s=&view=normal
So I am not sure why most suppliers say the SS lines will not work on the Type R. 94
Old Oct 24, 2012 | 01:17 PM
Fliptard's Avatar
they could possibly fit, sometimes different part numbers could just mean that the difference between an LS and type R brake line have a different bracket or mounting point, for example.
nero6
Honda Civic (2001 - 2005)
Aug 18, 2014 05:32 AM
hYbRid_Eg6
Apr 20, 2011 07:28 AM
integrase96
Sep 15, 2004 01:39 PM
ThePro
Oct 13, 2003 04:02 PM
2K_TEG
Feb 6, 2003 04:17 PM
